Need HELP!!...
I have a 99 VW Passat 1.8T, and for the past month or so once or twice a day I'll have problems getting it started. Or if it does start right up it will rev high then run ok, then may not start the next time. I can always get it going after a few tries, but I'm afraid I will get stuck somewhere, and have no clue what's wrong with it. Paul thinks the turbo may be going bad...any other ideas?
Thanks
Michelle
Thanks
Michelle
TF MILF Crew
TF MILF Crew
I don't think its the turbo but have you taken it to your local VW dealer yet?
Originally Posted by juke
I am going with the coil packs. What is your mileage?
oh one last thing....the Check Eng light comes on...and then will turn off from time to time....
A2 Element SC
Stock EK9
13 CR-V EL-L
A2 Element SC
Stock EK9
13 CR-V EL-L
Originally Posted by The Quad FaJ'a
one of the ICM go back some time back...but what the car is doing is realy odd...its almost like no gas for the 1st few sec's... its just turns over and will not start...then starts..and gets a high rev for a sec and falls off and idles right...the other thing we have noticed is that under acceleration it has some small hesitation..nothing big...thats what makes me thing the turbo is going bad...the car has 70,k on it...we got it with a little under 40k...
