Need HELP!!...
Old Jan 31, 2006 | 12:09 AM
Pdubinator's Avatar
White girls suck;)
my friends vr6 used to do the same thing, i say maf.
Always good to check air/fuel filter.
Diagnostic from a shop wont hurt tho.
Old Jan 31, 2006 | 05:20 AM
Daisylove1322's Avatar
~*Milfalicious*~
Thanks for the info..anyone know of a shop in the Brandon/Valrico/Temple Terrace area?
TF MILF Crew
Old Jan 31, 2006 | 02:27 PM
Justan8valve's Avatar
full color high res
i recommend this guy:
The Diagnostic Guy
501 S Falkenburg Rd
Tampa, FL 33619
(813) 685-3488
This guy is also pretty good:
Bergmans International Auto Works
126 Edwards Ave
Brandon, FL 33510
(813) 849-2369
Old Feb 2, 2006 | 10:04 PM
Zealot's Avatar
Easy like Sunday morning
MAF is more likely than the coilpacks, to check for sure just unplug it. If it runs smoother than you have found your problem.
Old Feb 3, 2006 | 09:33 PM
das_uber_hase's Avatar
gotta love those coil packs. i keep one in the trunk.
Old Feb 5, 2006 | 09:05 PM
Paul's Avatar
Motha Fawking Baby Maker
Unplug the MAS?
A2 Element SC
Stock EK9
13 CR-V EL-L
Old Feb 7, 2006 | 03:01 PM
  #17 (permalink)
Caan's Avatar
raising the standard
Yes, force the car to run on maps rather than signals.
Old Feb 9, 2006 | 07:22 PM
  #18 (permalink)
another shot that everyone looks over is the throttle position sensor. that can cause you to putt and surge.
Old Feb 9, 2006 | 08:01 PM
  #19 (permalink)
Zealot's Avatar
Originally Posted by The Quad FaJ'a
Unplug the MAS?
Yes what Caan said. If the MAF is faulty and sending bad signals, unplugging it causes the ECU to use default maps. If it runs smoother unplugged, than it safe to assume that the MAF is bad.
