12v and 24v block?
Old Dec 13, 2005 | 10:45 AM
SkwervE's Avatar
realer than most
Default 12v and 24v block?
are they the same? being both 2.8L i was wandering if its the same block...i know its kind of a noob question..
Old Dec 13, 2005 | 01:21 PM
GTIXpress's Avatar
VW Guru
No, there are some major differences between them. I don't remember exactly what they were, but I remember lots of discussions on VWVortex when the new motor came out.
Joe P.
2002 VW GTI 337
1969 VW Type III Squareback
www.vdubnut.com
Old Dec 14, 2005 | 07:39 AM
SkwervE's Avatar
realer than most
could you send me a link?
Old Dec 14, 2005 | 09:37 AM
BisquitMan's Avatar
Salad Tosser
Some coolant passages are different, the stud holes for the head are in different locations, other than that I think the blocks are the same. Bore size should still be the same, as well as deck height.
Old Dec 14, 2005 | 11:06 AM
SkwervE's Avatar
realer than most
im asking because i want to know if piston's and turbo manifolds will fit...i wasnt completely sure..
Old Dec 14, 2005 | 11:37 AM
BisquitMan's Avatar
Salad Tosser
The manifolds will be different, you will need the correct flanges for the 24v heads. I thought you were just asking about the block, the heads are different.
Old Dec 14, 2005 | 04:05 PM
SkwervE's Avatar
realer than most
will the pistons work?
Old Dec 14, 2005 | 05:58 PM
BisquitMan's Avatar
Salad Tosser
Yes
