2001 Jetta Wolfsburg
Old Jun 9, 2004 | 07:17 AM
BitbyStreetRacin's Avatar
once your bit, your done.
Default 2001 Jetta Wolfsburg
GLS 1.8T 20v
How many lbs. is the stock setup on? What type of turbo? (dimensions, etc.)
With a boost controller, what is the most boost you can run safely?
Old Jun 9, 2004 | 02:43 PM
dohc_neon95's Avatar
I got the same exact yr and model u do and i installed a boost guage in it and it pushes 7 lbs stock, but i threw a getto boost controller on it and got 11 lbs out of it and she flies. don't worry bout over boostin cause i had my controller set a bit hi and the needle flew to 15lbs when i floored it and some valve opened (the one next to the bov) and the boost went to 5, so i guess vw was smart and put some saftey thing on there so i dosent blow.
18 lbs of boost.....Upsolute chip, Tuned ECU, CAI, neuspeed side intercooler pipe, forge 007p Blow off / D/V, no muffler or resenator, high flow cat, stage 1 clutch, and light weight flywheel...for now...More coming soon. Looking for a Audi TT...
Old Jun 10, 2004 | 02:02 PM
Kyle K's Avatar
vw/audi
dont use boost controllers. .please. Just let the people who engineer chipped ecu's up the boost in your car..
Try www.goapr.com
Old Jun 10, 2004 | 07:04 PM
MDIFYTD's Avatar
Uber lurker
That's called soft limp and it's not a good thing. Kyle's right, go with a chip you'll get more power and it's also a much more reliable solution.
Ill say i go by His and Al's thoery of "Your getting sprayed" Doesnt matter what it is. Grandma in the 1982 LTD is gettin the bottle.
Old Jun 17, 2004 | 02:07 PM
VWFREFF's Avatar
World's Sexiest Fat Man
just call Revo and get yo shit chipped mang
originaly posted by 57trim aka Jazz
MOTHERBITCHFUCKSHITDAMN!!!!!!!!...........DIIIIG!! ! BITCH!!! DIIIIG!!!
TEH WHIPS!!!
I have a BIKE 06 Cannondale Prophet.
2002 EP3 Civic SI
Old Jun 17, 2004 | 02:16 PM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
Turbo is probably same one as the one in my avatar. Small, crappy, but spools like a mofo. Its done at ~2-3k RPMs but only ~9psi. Stops getting efficiency at ~13psi I've heard, DEFINETLY chip it though. Stock turbo is a Blitz KKK KO3, people upgrade to KO4s, T3/T4s, and a common but expencive one is the one I'm doing, the Disco Potato (GT28RS). The latter is your best bet for simple power, and theres a kit out for it, or should be anyways.
ASE: Brakes
Old Jun 20, 2004 | 01:55 AM
Zealot's Avatar
Easy like Sunday morning
Try www.goapr.com
Kyle's right, get chipped. I push 15lbs and spike to 18 under hard acceleration w/ APR's chip, which also provides the right amount of fuel for the higher boost levels
Old Jun 25, 2004 | 12:21 PM
15lbs??, I find that hard to believe. R u running that on the stock turbo? and what type of diverter valve do u got cause the stock one opens at about 13 lbs. The stock turbo is no good after about 13 lbs, I am surprised that your intake manifold gasket or head gasket hasent blown yet...
Old Sep 15, 2004 | 08:05 PM
So there isnt a way to raise the boost temporarily at all? Until we can get the chip or whatever?
Old Sep 15, 2004 | 09:45 PM
Kyle K's Avatar
vw/audi
The k03 can safely run no more than 15lbs sustained. Most chips you buy will put the k03 at around 1bar (14.7lbs). Stock is about 10psi i think.. But if you're talking about boosting more than 13 all the way through than you're slightly correct. The k03 is too small to run high sustained boost at higher rpms. The turbo gets "exhausted" towards redline and boost will start to taper.
The stock diverter valve opens regardless of the psi - that's why there's a vacum line attached to them. When you create any significant boost the vacum helps pull it open. Upgrading your diverter valve will not make a noticable change on the performance of the turbo! The 1.8t is a strong motor. The turbo will go way before the motor goes. For a whole lot of info try the vortex forums...
http://forums.vwvortex.com/zeromain?id=1
