Weldenator
ok tools that can be used with this deal
any ac tool that has brushes and NO variable trigger will run fine on dc
lights that are incandesent will work NOT flouresent NO transformers
cheap chop saws, drills, grinders,
when using a power tool raise the RPMs up to increase voltage
2200 RPMS was good for me at like 90 volts or so and it worked fine
to low of voltage with prolonged use can damage the tools as well so take care when useng them at lower voltage
i just clip the stinger to one plug and the ground to the other so i dont need a outlet
the stinger is well insulated and the ground will slide right in there
disclaimer : not my fault if you burn shit up
lol had to put this !
good shit man !
good shit man !
well i went to River rock ORV park
and did not even use this thing until
the trailer tire blew out and i needed a grinder to cut the fender away
my friends were like what the fuk are you doing hooking the welding leads to the grinder plug holy shit thats not going to work
but it did and perfectly by the way +1 for the weldenator for not exploding at 110 volts dc and 3000 rpms
