"CLUNK!" in the front end '03 F250 4X4
Old Jan 28, 2008 | 05:48 PM
Cecil's Avatar
gone fishin
Default "CLUNK!" in the front end '03 F250 4X4
I occasionally hear a very distinct "CLUNK!" in the front end of my truck.
Sounds mechanical, like a bad ball-joint or something.
It happens most frequently when taking off from a stop where I have to turn.
I've gone underneath to ensure everything is good and snug, as well as lubed.
Nothing "jumps-out" as suspect.
For the weird part.... I usually does it when it's wet.... either during or after rain.
Ideas?
The vehicle is a 2003 F-250 4X4 PSD Supercrew, short wheel base.
Thanks in advance.
Old Jan 28, 2008 | 06:22 PM
88RedRex's Avatar
Protected Taurus .45/.410
wheel bearing, jack up the front end and shake the wheel back and forth from side to side(right to left) there should be no play, and also if you have a big screw driver when the truck is jacked up stick it under the tire and pull up have a friend watch the ball joints, they shouldnt move but if they do then you need those
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
Old Jan 28, 2008 | 07:26 PM
Cecil's Avatar
gone fishin
Expensive?
Old Jan 28, 2008 | 08:59 PM
CRXSiR's Avatar
Fir Na Tine
bearings shouldnt be too bad..ball joints a little more than the bearings..
00 f250 ecsb
7.3 pstroke(92k miles)
2wd
wicked wheel 2
ebvp mod
s&b
5"magnaflow dump
custom 6position chip
05/07 grille
2010 Snapper Pro 36" z-turn
Kawi 19hp
45hrs
Old Jan 28, 2008 | 09:55 PM
Cecil's Avatar
gone fishin
thanks..... and for the love of Pete.... get some sleep.... insomniac
Old Jan 29, 2008 | 08:12 AM
CRXSiR's Avatar
Fir Na Tine
lol..i work nights bro...usually 6p-6a..so on my days off im still up to usually 3-4a..
00 f250 ecsb
2wd
wicked wheel 2
ebvp mod
s&b
5"magnaflow dump
05/07 grille
Kawi 19hp
45hrs
Old Jan 29, 2008 | 01:14 PM
88RedRex's Avatar
ball joints are about 500-600 at my shop, and bearings are alittle cheaper, but if you do the ball joints you have to get a alignment and i wouldnt even know what a alignment would cost to do that truck
MCOR Automotive LLC
Old Jan 29, 2008 | 01:51 PM
Jason.'s Avatar
Wheel bearings and ball joints are cake work, if your house is close to a tire kingdom, do it yourself and take it in to TK and get a lifetime alignment.
If you need a hand, we can make a day out of it on one of my days off this month
2011 Kia Optima SX Premium/Touring package
Old Jan 29, 2008 | 01:53 PM
Jason.'s Avatar
Been there, done that. It's hard to live a "normal" life when you work nights, so you just become a complete insomniac that everyone thinks is strung out on meth
Old Jan 29, 2008 | 03:56 PM
Cecil's Avatar
gone fishin
I just may love you.... in a very non-homo way
