Tow Capacity - Am I pushing it too far?
i would get a 5th wheel but you have a lift so i dont think it would work
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
MCOR Automotive LLC
only thing you might want to do over long distance is get a trans temp guage. we hauled a lot more than that with my old (02 7.3 F250), even went over the limit ford said it could hall, never with a problem. but i dont think you even at the limit of the truck so you should be safe, the trans temp guage is just a safty incase something doesnt go as it should.
Tractor Supply Company sells them.
dont think you will have an issue pulling wise.
Weight wise, i have seen plenty of trucks pull heavy equip on trailors like that all day long.
my question is, have you thought of and add-a-leaf. I would consult with the dealer about what the rating is on the hitch itself.
If i had the money and planed on buying a new trailor. me personally, i would go with a gooseneck/5th. You wont have the push and pull , side/side . like you would with a trailor hitch. On top of the gooseneck/5th sits over the axle so you dont make the truck do a wheelie.
above statment is only my opinion. Im not a rocket scientist, so dont hold anything against me.
Ok thanks.
I think you would be ok with it.You not going be pulling job sites stuff with it like small tractors and things.
Some guys here puts there trucks to the test max's them out really bad i have done that to my trucks few times..if something breaks and truck is still cover Ford will fix it thats good thing on most parts...
Ok thanks.
Need to replace the motor on the Jeep and hopefully slap some bigger tires and bumpers on the 4-wheelers ASAP.
Ready to head back up for some 4-wheelin love.
I went ahead and pulled the trigger on the trailer today.
I'll post up pics ina few days.
how come you need a new motor in the TJ?
00 f250 ecsb
7.3 pstroke(92k miles
2wd
wicked wheel 2
ebvp mod
s&b
5"magnaflow dump
custom 6position chip
05/07 grille
2010 Snapper Pro 36" z-turn
Kawi 19hp
45hrs
00 f250 ecsb
)2wd
wicked wheel 2
ebvp mod
s&b
5"magnaflow dump
05/07 grille
Kawi 19hp
45hrs
