parts for 64 c10?
well, ive had my 64 c10 for some time now and would like to start fixing it up some. main thing it needs is a new cab. mine has the small rear window but tons of rust above the front windsheild and it has caused rus on the bottom of the dash from water leaking on it. also the floor is shot and the rear window is getting rust at the top. other then that the truck is fairly solid. been swapped to 5 lug all around, 10 bolt rear(havent checked to see what gear yet) 4barrell 400sbc, powerglyde trans(i got a th400 to replace it already, just need to install), power brakes with front wheel disc, power steering, internal regulated alt and hei distributor. as far asi can tell the engine and full swapped drivetrain are from the same 74 truck. frame is still the origonal 64 wit thhe trailing arm rear suspension. truck has been lowered though i dont know excatly how far. its a project and i plan to complete it. anyway, if anyone knows where i can get some parts for it, mainly the cab in as good a shape as possible, and maybe the hood as well if its near perfect(mine isnt) thatd be great. thanks.
more pics on the car domain site in my sig.
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
Check out LMCtruck.com think you can find everythign your looking for there.
nope, they dont have cabs or hoods. they have the floor for the cab but thats it. as bad as my cab is the whole thing needs changed. and if i find a good hood for a good price ill replace that as well instead of fixing mine.
bump. still tryin to find a cab. anyone know one for sale? or a truck for parts with a good cab?
btw, this is pretty much my goal for the truck. except i plan on tourqe thrust 2 rims and a few other minor differences. drivetrain is pretty much done. once i get the cab i can prep the body for paint and get on the interior.
how bad is the cab, put in the new floor, and make some patch panels, were having a similar problem with the 68 4 door nova we are doing. having to make alot of parts our self.
its bad. where the metal meets the top of the windshield, there is no metal. botom of the metal das is rusted to hell. the top of the rear window is starting to go etc.. it needs replaced. way to far gone to fix.
have any pics of that? casue prolly alot more than you think can actually be fixed. and it dosent seem like your having any luck finding a cab, ive also looked around for you and foudn nothing.
