Jeep 2.5L?
Old Jun 6, 2006 | 12:09 PM
fordguy's Avatar
as long as you gear it right it will do just fine on road and offroad
No Limit Offroad inc.
727-647-5477
Old Jun 6, 2006 | 01:31 PM
SkwervE's Avatar
realer than most
so by me saying that have no tq...my statement is vague?
they dont have any tq..and i have seen far more lifted 4cyl jeeps getting stuck than the 6cyl and other swapped jeeps..
when we went out to rancho..we had a 4cyl jeep with us...it couldnt make it up the washout..and it couldnt make it through half the shit we all went through...but i dont know what im talking about..dont listen to me..
Old Jun 6, 2006 | 02:03 PM
CRXSiR's Avatar
Fir Na Tine
what would be the main things to look/listen for..?when in the 4wd..?he said all he has done was change the wheels and put 31s on it..he rhinolined the interior..full hard doors..ac..95k miles..its a 95..2 tops..once again..thanks!!
00 f250 ecsb
7.3 pstroke(92k miles)
2wd
wicked wheel 2
ebvp mod
s&b
5"magnaflow dump
custom 6position chip
05/07 grille
2010 Snapper Pro 36" z-turn
Kawi 19hp
45hrs
Old Jun 7, 2006 | 07:06 AM
TBSpyder's Avatar
You just want to listen/feel for anything out of the norm (mainly in the areas of the differentials/axles and tranny/transfer case, check for leaks around the transfer case, etc. Find out what he's done to maintain it...oil, tranny, and differential fluid changes. You'll probably want to do a full on tune up if you end up getting it to be sure everything is how it should be.
Old Jun 7, 2006 | 02:40 PM
Amortized's Avatar
Mortgage Man
engines don't get you stuck, low clearance and too small of a tire does. besides the gearing on the 4 banger makes up for the lost torque of the 6.
http://www.tampaforums.com/forums/in...g-you-off.html
How to keep a mortgage broker from ripping you off!
CWB
Old Jun 8, 2006 | 01:15 PM
TBSpyder's Avatar
You should add inexperienced offroaders to that list as well.
Old Jun 8, 2006 | 04:25 PM
  #17 (permalink)
SkwervE's Avatar
realer than most
um...not really..
so if an under powered motor cant turn the tires thats on it..how is it supposed to move? what fun is it to mud sling in creep mode? 4cyl jeeps have no balls..and they get stuck more often than anything else i see..
Old Jun 8, 2006 | 07:29 PM
  #18 (permalink)
Amortized's Avatar
Mortgage Man
um...not really..
if the tire isn't spinning the diff is open and your other tire is spinning like mad, if you've got lockers and the tires aren't spinning, your clutch/torque convertor is slipping. people very very very rarely get stuck because they can't turn their tires, and if they do, they are running a huge tire with massive amount of tractions, and in which case they need to regear anyway. your argument sucks, admit it.
CWB
Old Jun 8, 2006 | 07:32 PM
  #19 (permalink)
Amortized's Avatar
Mortgage Man
that's not the motors fault.
CWB
Old Jun 9, 2006 | 10:31 AM
  #20 (permalink)
TBSpyder's Avatar
um...not really..
It's called gearing.
