how to check the cel light open toyota gurus
Old Mar 24, 2012 | 02:59 PM
fanatic22's Avatar
deebeetoo
Default how to check the cel light open toyota gurus
hey i have a 1993 toyota mr2 and its giving me a check engine light.. how can i check the light my self ?????
help would be greatly appriciated
Old Apr 2, 2012 | 03:43 PM
kanji1jz's Avatar
jza70r
Jump te1 and e1, turn key to on, count flashes of cel. If you need code definitions text me the codes.. I will tell you what they are a little later on this evening.
89 jza70r
3" exhaust w/ apexi muffler
xs engineering intercooler
sportmax 962 17x9 (r) and 17x7.5 (f)
kelly charger hpt tires
eibach lowering springs
kyb struts
sneed speed shop dual electric fans
max steel solid engine and trans mounts
walbro 255 fuel pump
custom 2.75" intercooler piping
R.F.L. bov (not a big fan but it gets the job done for now)
Old Apr 23, 2012 | 05:08 AM
kanji1jz's Avatar
jza70r
If it is number 11 as you have described in your pm, then it's a short in the squib (center airbag) circuit or front airbag sensor circuit to ground.
89 jza70r
kyb struts
nyboricuakid
Apr 28, 2009 07:15 PM
evol_crx_si
Jun 5, 2006 01:36 AM
gotvtec20
Oct 28, 2002 05:50 AM
