need help mk3 supra 87
so i have a 7mgte supra and it was running fine but then the battery had died. and my friend put the jumper cables on backwards. so now all it does is crank but its not getting any spark, so idk what the problem is. i tried changing the ecu and doesnt make a difference. any other idead? maybe the coil pack blew? idk can anyone help me?
could have fried the igniter.
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
Did you check all the fuses? What have you tried so far as diagnosis goes?
89 jza70r
3" exhaust w/ apexi muffler
xs engineering intercooler
sportmax 962 17x9 (r) and 17x7.5 (f)
kelly charger hpt tires
eibach lowering springs
kyb struts
sneed speed shop dual electric fans
max steel solid engine and trans mounts
walbro 255 fuel pump
custom 2.75" intercooler piping
R.F.L. bov (not a big fan but it gets the job done for now)
89 jza70r
kyb struts
a light tester? you mean a voltage tester? and no, that would not mean they are fried. that would mean they are not getting voltage, or if you mean tested them for spark, that means they arnt being triggered. they are triggered by the igniter, which is triggered by the ecu. go to the link i posted and test your igniter. sounds like the igniter is fried, not the coils.
If you end up needing an Ignitor, I have two extras. You can have one for twenty bucks.
