need help mk3 supra 87
Old Nov 8, 2011 | 07:07 PM
amores213's Avatar
alright thanks ill keep that in mind. actually i might get it by this weekend.
Old Nov 9, 2011 | 07:17 PM
amores213's Avatar
okay soooo i swapped out the ecu and coil packs and igniter but theres no CEL . and all it does it crank it doesnt wanna turn over ,
the CEL doesnt turn on at all.
Old Nov 11, 2011 | 10:19 AM
williamb82's Avatar
grease monkey!
cranking is turning over. have you checked all the fuses and circuit breakers and fusable links? is the ecu getting power at b and b+? if so, does mrel have power when the key is in the on position? do you have power at the coils and the igniter when the key is in the on position?
if you dont have a clue what im talking about, i can come look at it and tell you was wrong for $50 as long as you arnt too far from me.
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
Old Nov 11, 2011 | 11:03 PM
amores213's Avatar
we found the problem it was the main relay, thanks everyone for the help i really appreciate it.
Alpha
Induction Performance
24
May 10, 2011 05:23 PM
BGRIF
Sep 7, 2008 10:44 PM
Mysterious Driver
Aug 4, 2007 01:40 PM
Figs
Mar 8, 2006 08:23 AM
