Sputtering problem
Toyota Tacoma, 3.4 liter v6(5vz).
Ive had a sputtering problem for a while, comes and goes. Replaced the plugs, coilpacks, wires, cleaned injectors, compression is good. Usually happens if its idleing, or if im just cruising at a normal speed. If I cruise, it would sputter a bit and as soon as as pressed the throttle a bit it would go away for a while. I can feel the loss in power and sometimes got a cel for a misfire.
The compression is good, the ecu replaced with a megasquirt, no smoking. The truck is turbod now(it started this problem when it was supercharged but went away). Any clues or ideas?
Headgasket? Valves?
Headgasket? Valves?
Have you ever seen a man eat his own head?!
