Hi I Have Is300 I Need Help Plzzz :)
Hello Im 17 I Just Bought My 2003 Is3oo I Want To Work My Way On To Boosting It. It Is A 5speed 2jz Ge Stock Motor With 65k On It I Dont Weather To Build This Motor Or Just Swap It To The 2jz Gte 6speed And If I Do Swap It Would I Be Abel To Sell My Stock Motor ????? I Personally Think It Would Be Cheaper To Swap It Tell Me If Im Wrong Please If You Can Please Try And Give Me Some Good Advice Thank Youuu
if you plan on down time you can achive good power from the stock GE boosted.
I personally think the better way is to just do the GTE swap, just go on my.is and clublexus and even supraforums to get better answers
I roll fenders on any car and do valve adjustments on Honda's and Acura's
Ex Acura Tech
Ex Acura Tech
depends on the power you're looking for honestly
so if your goals are not ridiculously high the stock motor and tranny will be just fine
no reason to swap it
also the stock motor is almost worthless as far as selling..you'd typically get only a few hundred bucks for them..
also its not cheaper to swap it. why? you have to buy a 2jzgte $2000+ right there(thats for the cheaper auto swap)..then u have to pay to have it swapped...probably another $2000 or so depending on the place you take it too..unless you plan to do it yourself
then if u wanted a v160..another $3000+ for that tranny alone
if you wanted an xs power turbo kit for a NA-t setup..they are about $1800 then you need it installed plus some engine management...stock injectors/hg will do for a moderate 300-330whp which would be nice imo...
check out clubna-t.com and do some research there also.
vvt-i 2jz-gte motors run around 1800, can bolt it to the w55 and will hold stock power for enough time to save up for an r154 =-p
a good na-t setup will run around $5,000 including engine management and injectors. Xs power kits have decent piping but use super cheap turbos, wastegates, boost controllers, etc..
Doing both jobs CORRECTLY will cost about the same
1320 Inc./////
Call - 813-842-0505
Email Info@just1320.com
http://www.just1320.com
8602 Temple Terrace Hwy. C-14
Tampa FL 33637
4ws tuning
Boost Lab
1320 Inc./////
Call - 813-842-0505
Tampa FL 33637
4ws tuning
I think you can piece together a good na-t kit with some used parts and a rebuilt turbo for cheaper than that though, unless the is300 is alot harder to go na-t than an sc300.
Its a Yota not a Honda... Go to toyota tech and post there
