Tranny Issues Plz Help
Old Jan 1, 2010 | 09:19 AM
22R's Avatar
22R
Default Tranny Issues Plz Help
i just installed my new tranny into my 86 toyota pickup but its already showing some issues like third gear is really hard to get into and also the speedometer is marking almost 10mph ahead of what it should it sucks alot .... by the way its a w58 tranny ........ seriously i spent money on the tranny and oil and seals any help would be great and appreciated ..... also the shifts feal sloopy but the shifter bushing doesnt seem bad.... PLEASE HELP OUT GUYS I DONT WANT TO FIND OUT I LOST MY MONEY.....
Old Jan 3, 2010 | 03:49 PM
kumar.'s Avatar
wrd.
ttt. any help or thoughts are appreciated!
btw, it's sameer man.
"Success is 99% failure" -Soichiro Honda
Old Jan 3, 2010 | 03:55 PM
22R's Avatar
22R
hey man was up bro .... yeah the tranny is running well but the gears feal crappy specialy 3rd shit tranny!!!! and my speedometer is way off!!! nobody here has helped me so far it sucks
Old Jan 3, 2010 | 04:30 PM
Hater's Avatar
Free base cocaine
speedometer is off because your diff is a diffrent ratio then a supra or w.e the w58 came out of him.
Did you inspect the tranny at all?
Old Jan 3, 2010 | 04:35 PM
22R's Avatar
22R
ive never worked on transmissions at all exept for a clutch install but by the looks of it it didnt show any past leaks or much harm, it went into all gears .... i know rookie mistake i should of taken someone that knew something bout trannies any pointers on what to do???
Old Jan 7, 2010 | 05:08 PM
flyspyder55's Avatar
hey, i recently sold a w58 to someone with a truck and i think it might be you. i dont know why it would have any issues, it shifted and ran great when pulled from the last car it was in (my baby, 76 celica coupe)
what are you using for transmission fluids, also are you sure the clutch pedal is adjusted properly?
if the transmission is indeed defective, i would gladly take the tranny back and give you a refund.
w's feel a bit sloppy no matter how fresh they are. it sounds like it might be a pedal issue
Branden Berger
352-789-0006
86.5 toyota supra- 1jz never to be finished
01 mitsu eclipse v6 5mt chick car daily
98 honda accord ex- h22 swapped daily driver
Old Jan 7, 2010 | 06:40 PM
22R's Avatar
22R
update ... the tranny is running better but the gears are abit hard to go into until its been used for bout 5min. after that its pretty smooth sloppoy but smooth lol ....... and yeah im the one u sold the tranny to but noo need for a refund man thanks ..... so does anyone know how i could fix the speedo problem??? also since you asked what fluid should i be using ??? cause im just using vavoline sumtn 90 for now but i plan on changing it just clean it out realy well since it hasnt been in use .... anyways thanks everyone for their input and help
Old Jan 7, 2010 | 06:42 PM
302GTS's Avatar
Resident TOB Killer
Sorry this is a wasted post, and hopefully the issue is resolved but what I quoted really shows how good some people are on here. Rep'd, man!
Old Jan 8, 2010 | 06:31 AM
williamb82's Avatar
grease monkey!
if you put synthetic fluid in it drain it out and use reg crappy walmart gear oil. itll shift better. synthetic usually doesnt allow the synchros to grab. sounds like the problem your having honestly. ive dealt with this on r154's many times.
as for the speedo issue, you need to find out what rear diff gears you have and get the speedo gears to match for the trans. they are kind of a pita to change.
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
Old Jan 8, 2010 | 04:48 PM
definitly pita to install the gears... just find a 3.43 gear for the rearend... wouldnt celicasupra R&P's work? i think william would be the one to ask.
the trucks are all geared to high anyway. i ran a 4.33 on my 22r in the celica kinda sucked on the highway but nothing horrid
Branden Berger
352-789-0006
