sc300 5 speed conversion question
Old Mar 5, 2009 | 05:53 AM
Hater's Avatar
Free base cocaine
You could very well destroy a W58 on a stock na 2J. But, if this is your daily driver it wont be so bad, as long as you baby it. Fuck, ive heard of stock 7m's grenading one of these drifting.
Also, 1500 for the transmission is ridiculous, ive seen them go for around the $700 range, and if you lurk the salvage yard for long enough you can probably find one. Or even ebay.
Old Mar 5, 2009 | 06:16 AM
soarer_owner's Avatar
do the research bro....where in the hell are u gonna find a r154 for a soarar/sc300....in a junk yard here...everyone knos that if u have a real soarer r154 that it goes for 1000 bucks up...there is a difference btw a mk3 r154 and soarer r154...
[SIGPIC]
94 1jz 5spd JZZ31
Intake, 3" Downpipe, 3" Full(Blitz Nur Spec)custom exhaust, SAFC 2, Supra TT Shocks, Supra TT Eibach lowering Springs, SC400 Lip, 6000K Hid's, LS400 BBK(calipers painted black), Cross Drilled/Slotted Rotors, SSR D5R *245/40/18 F 245/45/18 R*, Auto->5spd Swap*W58*, CenterForce Dual Friction Clutch
5spd swap completed!!
1jz/Blitz tuned Ecu completed!!
Old Mar 5, 2009 | 05:49 PM
Hater's Avatar
Free base cocaine
And that difference is....?
Ebay that shit der, you can go out and get one right now for $1000 sure, but who does that!?
You also said in your first post that they go for $1500, I think you need to do some research.
Old Mar 5, 2009 | 06:01 PM
ROPADOPA's Avatar
the diference is about 500 bucks
Old Mar 5, 2009 | 07:48 PM
thank u rob...tell that dude again....he needs to do some soul searchin...and learn the difference btw a supra r154 and a soarer r154!!!!
[SIGPIC]
94 1jz 5spd JZZ31
Old Mar 8, 2009 | 02:22 PM
82RollaSR5's Avatar
Toyotas For Life
driftmotion.com has every single thing you need. Even the whole clutch pedal set
Old Mar 18, 2009 | 07:18 AM
  #17 (permalink)
shonanspeed's Avatar
TR Balla Donor Supreme
The clutch pedal is annoying if you get a w58 and don't get an sc pedal. I used a MKIII supra pedal for mine but had to do some modification to it so it wasn't hitting the footrest on the left. I eventually got around to taking it out. If you're going to build the car your tranny choice should work backwards- desired hp=what tranny you use. I regret my w58- I have to drop it back out now or it'll blow the first time I miss a shift. w58- low hp, r154 or v160 getrag 6 speed- much higher hp (yes, r154 needs 1j bellhousing and I think you have to mod the shifter but you can find the tranny's cheap on ebay), getrag is expensive, and you can always go with a th400 or boostlogics built auto (which I believe is a Turbo 400). If you are low on funds I suggest skipping the swap altogether until you have more cash and can go with something better than the w58.
Old Mar 18, 2009 | 07:43 AM
  #18 (permalink)
G-Magoo's Avatar
July - Ride of the Month
....the shifter extenstion....
Soarer on the left, mk3 supra on right. See the difference?
I love haters..
Originally Posted by VR6exxy
I love your brutal honesty. It makes my day
Build thread
Old Mar 18, 2009 | 02:08 PM
  #19 (permalink)
Locobori86's Avatar
pm aliga on club lexus and he will sell you the swap for a good deal...it sucks auto diff with 5 speed setup...best bet is get factory five speed. I have a 2jzgte with a w58...the tranny holds fine...just dont be an animal when shifting...my car made 400 with a w58 and a spec stage 3
Old Mar 18, 2009 | 08:24 PM
  #20 (permalink)
Hater's Avatar
Free base cocaine
At least thats a legitimate response... barely at that.
soarer_owner I would say you would have to be the most ill informed person to be giving this person advice. You start saying the tranny is 1500, then 1000, then when asked the difference, nothing. "about 500." We're trying to help this guy and miss-information isnt helping, or you poor use of the english language.
