22R questions
Old Apr 20, 2008 | 05:55 AM
89crxsir's Avatar
Default 22R questions
Anyone in here a big fan of the 22r engine, or knows a lot about them? If you do, i got some questions...
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Old Apr 20, 2008 | 06:12 AM
93LowBody's Avatar
TR Balla Donor Supreme
I know a little bit... ask a way.
Old Apr 20, 2008 | 06:58 AM
89crxsir's Avatar
i'm doing timing chain, water pump, head gasket. while i have the engine 1/2 tore down, i want to get rid of the smog stuff. I can't find anything on line about it and Lc Engineering have a egr block off kit http://www.toyotacatalog.net/M1WebGe...4-D715971CF42D SO i'm guessing one part goes over the egr in the intake and the other one goes over the exhust manifold, but where does the the last one go?
Old Apr 20, 2008 | 07:15 AM
93LowBody's Avatar
the top left one goes on the back of the intake manifold. the Center goes on the passenger back side of the head. the right one is the block off for the Carb`d manifolds.
You may also want to get http://www.toyotacatalog.net/M1WebGe...6-23409DA05DC0 to block off the crossover on the back of the head.
31.85 for the 3 plates that you need... or you can just buy the kit you linked to and leave the stock crossover on.
Old Apr 20, 2008 | 07:28 AM
89crxsir's Avatar
http://i88.photobucket.com/albums/k1...9/DSCF1408.jpg
So what would cover this hole??
Old Apr 20, 2008 | 07:34 AM
93LowBody's Avatar
^ that hole is for your stock O2 sensor.
http://www.toyotacatalog.net/M1WebGe...5-70EC574B6B02
thats the block off for it
Old Apr 20, 2008 | 07:57 AM
89crxsir's Avatar
ok, thats where the pipe goes to the egr valve.
Old Apr 20, 2008 | 08:07 AM
93LowBody's Avatar
?? um maybe on the trucks.
on my celica its the O2 sensor.
Old Apr 20, 2008 | 09:17 AM
89crxsir's Avatar
yea.... i'm the carb version.. so i don't have an o2. check your pm..
Old Apr 20, 2008 | 09:20 AM
HellofaPrzeFghtr's Avatar
The One and Only
The EGR in the celica was blocked off if you noticed.
