built 20v almost done jeff needs help
Old Mar 23, 2008 | 10:22 PM
DouglasProbe's Avatar
Version 5
Default built 20v almost done jeff needs help
this email is probably gonna be all mixed up, i posted it first of msextra forums, then club4ag... below you will read what taylor and i have been dealing with....well most taylor im just trying to develop my other mechanic skills
the car is gonna be hot and taylor has been bustin ass. but again we encountered megasquirt problems. i wanna learn/do this with out taylor and i imagine someone has just configuratin megasquirt knowledge ....ill hit you back
dig though the post, at the end you will see that im looking for simple setting.ini and configuration stuff to get my mega2v3 to run edis..... i have grat maps from car taylor did back in the day maybe we can make them work. if not ill enter the values mechanically.
i posted this on msextra forums, but ive shared maps with you guys and was hoping for a more timely and caring response. this is gonna sound newbie but exclusive of this issue my 86 and automotive knowledge has grown. below is what i posted on ms forum you read whats been goin down or jump to the bottom to see the help im looking for
thanks guys jeff
nyway after a year or so and the help of local wiring guru taylor durdan my 20v into my clean hatch is ready to run.
let me recap a few problems, under someones advice i bought what was supposed to be a working megasquirt 2 version 3....should be good to for edis use.
great harness is made, taylor does bomb fabrication then we crack open the ecu to see it was poorly assembled cold soldered all over. taylor new a tampa local ecu genius that for 20 bucks fix a bunch, resolder stuff, get the leds in right order etc....
today i learned that taylor still had to do some soldering to get the megasquirt II to run our edis setup. (im learning my mechaninic but have miles to go in terms of electrics wiring etc....) anyway taylor left me with the impression he got fuel spark etc from the ecu we just need it to setup for edis and then hopefully uses the values taylor assisted in building marks 20v hatch MegaSquirt Success Stories • View topic - Mark Gearhart, 1986 Corolla GTS with 20v blacktop swap
regardless of getting those values in need some newbie guidance on setting up my ini file to get the ecu to realize its running for edis. I don't doubt that i could configure it myself. but my project is so close and taylor is mad busy with work....ive been sharing maps to forums.club4ag kids 20v maps and could appreciate any help.
I need basic guide through or existing setup or ini file to get me started. i keep encountering errors that megatuneii.ini cannot be found
if that can be solved mad appreciation. and ill throw out another request using these files Index of /rolla/mega
how can incorpate them into my megasquirt. is he using a different version with an EDIS code? or is there a way to read his values and enter them into mine.
i know this email was all over the place but its late and im rushing to get running at least. i wanna learn too, which is why im not just waiting for my boy do it. please
fill me
email me files klein76@gmail.com
or call me 727.421.1311 or just post
thanks
