Need Help with MR2
Old Apr 1, 2007 | 03:35 PM
VikingWarrior's Avatar
Default Need Help with MR2
Hey guys Im new to the MR2 game. Got an MR2 with a fresh 3SGTE swap into it and my check oil will not shut off. Oil level is good and compression test was good. Wondering if you guys could throw me some advice.
Old Apr 1, 2007 | 03:39 PM
Idealsupra's Avatar
I Hate Fuel Cut
have you checked the sensor?
Old Apr 1, 2007 | 04:57 PM
MR2driver's Avatar
not available
Is it a JDM motor? They do not have the oil level sensor, and usdm versions do. So you probably need to just pop the light out of the dash or cut the whire.
Old Apr 1, 2007 | 07:50 PM
2kSnakeater's Avatar
Pastafarian FOR LIFE!!!!!
Dont pop the bulb off, OR cut the wire. Just change the oil pan from a USDM mr2. They shouldnt cost that much and it will look like its a 100% factory. If it is a USDM motor then your sensor could be out, look at the oil pan near the main pulley and you should see the sensor right there.
sig under construction
Old Apr 9, 2007 | 09:20 PM
MR2driver's Avatar
not available
It will look the same except for the fact it doesn't have any emissions control devices on it.
Old Apr 9, 2007 | 10:52 PM
nd4spd86's Avatar
boost happy
if your oil pan doesnt have the sensor you should see a plug hanging down either by your crank pully or underneath your intake manifold that isnt going to anything... you should be able to just jump this out and your light should go out (disclaimer: i am not responsible if you jump the wrong plug and fuck something up)
Old Apr 10, 2007 | 05:41 AM
christo4_99's Avatar
i have the oil pan and sensor if he wants to go that route...
the way i see it,if you combine two words,like bull and shit...well,you know the rest
