mkiv supra help
Old Apr 3, 2007 | 12:15 PM
  #21 (permalink)
Kirk's Avatar
Boostaholic
Are you the one with the white supra that was next to me on 275 to the 56 exit?
BOOST LAB, INC.
95 Toyota Supra Turbo - 1000HP
http://www.TheBoostLab.com
TURBO SERVICING & SALES | FUEL INJECTOR SERVICING
GARRETT - BORGWARNER - BULLSEYE - HOLSET - 3K
TiAL - TURBONETICS - FULLRACE - PRECISION
Shop Forum | FaceBook | Website | Online Store
Old Apr 3, 2007 | 03:32 PM
  #22 (permalink)
JZA80's Avatar
yeah that was me on 275, my wife was half asleep telling me ''you better not try to race''. plus I had my kid in the back seat. I tried to race quitely flooring it in 5th gear. it even misfired then.
just today while leaving work, the supra wouldn't move forward, the misfiring was so bad for about 2 seconds then finally went back to normal.
I turned around and scanned the obd2 swapped ecu, no misfire codes active or history.
I did have the usual trac disabled code and a P1162 exhaust bypass valve circuit malfunction, which I'm gonna look into. it may just be the vacume t mod making 15psi.
I am gonna re gap my plugs tommorrow. sorry for such a long post. this sucks.
oh yeah. I do have the denso ik22 iridium plugs (1 heat range cooler than stock). I am going to regap them, check connectors on coils, clean out the aem air filter, and see how that goes.
Old Apr 3, 2007 | 03:44 PM
  #23 (permalink)
Kirk's Avatar
Boostaholic
Do you have an boost cut controller on the car ? You may be hitting boost cut @ 15psi which explains the "miss-fire". Do you live in the New Tampa Area? If so I don't mind helping you check over the car. I live off of 54 where the new Ferman Dealership is at.
BOOST LAB, INC.
Old Apr 4, 2007 | 04:38 AM
  #24 (permalink)
JZA80's Avatar
I do have the greddy bcc installed and operating (spike at 18-20 psi) with no cut.
to add to the mayhem. last night found out via wideband that car not entering closed loop, I can tune my idle with my apexi neo, (usually not possible while in closed loop). 3 month old oem o2 sensor. it may or may not be related to the high rpm misfires.
I was told to check my coolant temp sensor. well see
I've still got to check into the basics 1st.
as far as new tampa goes. I just temporarily moved last night back to tampa with family, (in process of trying to sell old and find new home) so I've got very limited time, but I appreciate the offer to help diagnose this. I'm gonna try the basics 1st, it may be something stupid.
ill repost in a few days, I got too much goin on, now and days. life is too busy.
sometimes I wish I was omish (with a supra)
Old Apr 4, 2007 | 08:02 AM
  #25 (permalink)
pheobo's Avatar
Boom Chackalacka
I would make sure you check the connectors to the coil packs. Now it's misfiring at more then just high RPMS.
Use a resistor to get rid of the TRAC code. mkiv.com I believe has an article on it.
200+ MPH Club
1000+ HP Club
Old Apr 8, 2007 | 04:07 PM
  #26 (permalink)
722ish's Avatar
ASM FTW!
It wont be cats or any stuff like that. I would see if you have a MAF leak if you still have one. All the intercooler piping, TB gaskets/IM gaskets could be leaking. Also, you should pop out the plugs after a few days of driving them so far, and take some pictures. Post them up and maybe some of us here can be of more assistance. I have no experience with the IK plugs, only NGK 6097 and 3330's. Is the IK22 or whatever a reccomended BPU plug on SF or on TSF? My car would break up up top as well. I had a problem with my BCC, however it would not in neutral, or at slow speed. Mostly second gear with lots of wheelspin!
good luck!
Mark
95 Supra Turbo 6 speed
11 SWP STI sedan
Old Apr 11, 2007 | 06:17 PM
  #27 (permalink)
JZA80's Avatar
Awesome. I think its finally fixed. Quick Recap.
The car would misfire when you floor it in neutral, sometimes while driving at high rpms or downshifting.
It turned out that there was a cold joint in the odometer circuit board. I saw a writeup on supraforums.com, other people have noticed this also.
Something about the speed signal that runs through it, the soldering point for it goes bad. All I did is dis-assemble the odometer and touch up each soldering point. Has worked fine ever since (which has only been 12 hrs btw).
Hopefully it doesnt come back.
I did also check all connectors, plug gap, air filter cleaning, and etc. in addition but never got better untill I took apart the odometer.
Thanks All
Old Apr 11, 2007 | 09:46 PM
  #28 (permalink)
Troux's Avatar
Cold joints have been a number of problems on these cars...
