SR5 with a 4AGE??????
Old Feb 13, 2007 | 08:31 AM
cynicalmonstar's Avatar
Default SR5 with a 4AGE??????
I know this has probable been covered. However I can t find anything but an sr5 conversion to gts. I don t wanna convert the whole thing just the motor. Whats it goina take to get a 4age in my POS SR5? Is the cluster and shit needed? Some one help me. Thanks
Old Feb 13, 2007 | 11:08 AM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
youll need the engine and harness. the ecu. the gts trannsmission (really just the bellhousing). the stock speedo gauge will work. you might need a gts gastank but ive seen people use the sr5 tank just fine.
theres other random things im leaving out.
Old Feb 13, 2007 | 05:16 PM
1luckybstrd's Avatar
you can use the sr5 tank but you do need the gts fuel pump. I just recently did the conversion myself. Also your gonna need the rearend (lsd) if you really wanna do the conversion right.
Old Feb 13, 2007 | 05:18 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
you use the gts pump or an aftermarket pump as well.
Old Feb 14, 2007 | 12:09 PM
YOTA ROBERT's Avatar
the bellhousings are the same so ur straight
Old Feb 15, 2007 | 03:47 PM
Troux's Avatar
How much easier is it to go straight from an sr5 to a carb'd 4AGE?
Old Feb 15, 2007 | 08:05 PM
ok now i am more confused. so this is my list ECU, harness, motor, i am not trying to convert to a gts just get the 4age in there. specifically a 4agze block. thinkin bout turboin to bout 10 psi. wanted to be stupid and turbo carb a single cam but i can t find any help. does anyone kno anything bout a 4ac head on 4age block? i have a side draft weber that i was goina use. i jus need some help.
Old Feb 15, 2007 | 08:11 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
dude just buy my car
Old Feb 15, 2007 | 09:11 PM
i live n wv not fl. i d rather live there cuz it is literally 5 degrees outside. however i am on house arrest 4 awhile n need sumthin 2 keep me occupied.
Old Feb 18, 2007 | 04:07 PM
djbomberto's Avatar
how much? *wink* *wink*
