Help ne, MkIII Supra Tuners
Old Jan 8, 2007 | 11:27 AM
Bftsupra's Avatar
Default Help ne, MkIII Supra Tuners
Any supra tuners out there? I put a new turbo on my car last week and am having a hard time tuning it properly. It is a gt35r with .82 a/r turbine.
I am using safc 2 and LM 1 wideband to tune it. First few runs it were pig rich and getting fuel cut like mad.
I turned the afpr down to about 30 psi with the vac hose off, but still am having to put in so much correction with the safc 2 that it is pulling timing.
So far It looks like this:
2400rpm - +5% corr - 15.7 af
3000rpm - +5% corr - 12.1 af
3600rpm - -25% corr - 11.7 af
4200rpm - -30% corr - 12.5 af
4800rpm - -28% corr - 11.2 af
5400rpm - -32% corr - 10.4 af
6000rpm - -20% corr - 10.5 af
2400rpm - -24% corr - 10.7 af
I am trying to get 11.8 -12 af. This is boosting at 15 psi, but I really hoped to run this at about 20 psi.
Pulls great from aobut 3500 to about 5000 or so where it softens up a lot presumably from timing being pulled.
Any one know what I need to do next?
I tried to get Ryan at XAT to look at it, but he no longer works there. Anyone know where he went?
Old Jan 8, 2007 | 12:20 PM
The Reaper's Avatar
Project:: Reaper
other mods???
injectors?
lex afm?
fuel pump?
Old Jan 8, 2007 | 02:21 PM
Bftsupra's Avatar
All the usual stuff walbro 255, rc 550s, lex afm, apexi intake, tubular manifold.
Old Jan 9, 2007 | 07:12 AM
williamb82's Avatar
grease monkey!
whatever you do is gonna be counter acted by the ecu at anything other then wot. looks like it needs leaned out up top. id adjust it 2-3% leaner at each 10.x:1 afr then run again and check it on the datalog. also did you back out the screw on the afm to allow more air to raise the fuel cut?
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
Old Jan 9, 2007 | 07:16 AM
The Reaper's Avatar
Project:: Reaper
i never messed with the screw on my lex
i dunno what could be causing yur prob. something with the AFPR maybe?
Old Jan 9, 2007 | 07:57 AM
psifactor's Avatar
Hello
Word on the street is he is at Stadium Toyota.
well if you are running rich up top just pull out more fuel. As you mentioned you have no wait to monitor or adjust timing so the more fuel you pull out the more timing you are pulling. I've used just an afc for awhile now but I guess if you wanted to be 100% safe its time to move onto something you can monitor and adjust timing with.
Heavy car with a 2.5L
Old Jan 9, 2007 | 01:32 PM
_Victor_'s Avatar
Induction Performance
Hes not at stadium Hes at the one on Fletcher I believe....But If you need someone to check the car out you can stop by the shop sometime I'd be more then happy to help you out.
2005 Mitsubishi Evolution. -Sold
1994 Toyota Supra 1249rwhp -Sold
http://www.youtube.com/watch?v=Se7lR...eature=related
http://www.youtube.com/watch?v=tJOcnI5CMe8
1990 Toyota Supra 7MGTE
814rwhp -Sold
Old Jan 9, 2007 | 06:29 PM
Bftsupra's Avatar
Thanx for the replies.
I don't think I will complicate matters by screwing around with my timing just yet.
I am reasonably sure it is a recurring problem with my intake manifold not sealing on cyl 1 and 6. I have replaced the gasket twice from it being blown, each time thinking this time for sure. Literally 1/2" piece missing on cyl 6 last time. I think I will take it to a machine shop and have the surface checked for true and maybe milled this time.
I been meaning to stop by the shop, and intend to when time permits. You open on Sat.?
Old Jan 10, 2007 | 11:46 AM
J-Dizzle's Avatar
Still Addicted to Boost
they no there shit, just go there ...hahahahah....im pretty sure i see them open on saturdays
Don't Text And Drive
Old Jan 11, 2007 | 04:23 PM
agentAndy's Avatar
more class than college
7m's and their silly gaskits.
get that car on a dyno.
street tunning will never get you a better result than on a dyno.
xat-813-875-7223
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
