need help on my supra
Old Jul 3, 2006 | 11:44 AM
jst4shw's Avatar
Default need help on my supra
need help!!!!!!!!
i just bought me a 87 supra turbo( 7m-gte) but the car was in the driveway for like a year and it was running before ,,, the reason why they park it was because the speedometer quit working,....now i`m trying to figure out y the car doesn`t start but it turns over ,, i pulled the spark plug out to see if i get sparks ,,yep ,it does,..,,but then it seems like i dont get no fuel , the spark plug was dry when i pulled it out and i dont smell no gas ,, so i check the EFI Fuse but then it was blown so i change to a new one ,,try to start it!! the fuse was blown again,, so i change it to 20amp(it was 15),, now its working but the engine still doesn`t crank up,,,,,,next thing i`m gonna do is to change my fuel flter,, then check my fuel pump,,,,,,,,this is my firsttime owning a toyota ,, so i need help from you guys,, thnks
Old Jul 3, 2006 | 01:18 PM
sonicwrx's Avatar
try the toyota forums
Old Jul 3, 2006 | 03:11 PM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
If the EFI fuse keeps blowing, then thats not the problem. Theres a reason why the EFI fuse keeps blowing. Follow the wiring and see why it does.
The fuel filters on MkIIIs are supposedly a pain in the bitch to get to, mostly I think because they were meant to be "lifetime" filters that dont need replacement. Only occasionaly do they need replacement, though some times they really do.
Good luck!
ASE: Brakes
Old Jul 6, 2006 | 08:36 AM
Skim1040's Avatar
1slomk3
If it was sitting for a while, there could be a possibilty of the pump or the injectors getting gummed up and possibly clogged.
TreeTop Militia
Old Jul 7, 2006 | 12:36 PM
Slash's Avatar
THE HAMMER
The gas may even be so gone off that its not even going to provide a decent combustable material. I would start by draining the tank and cleaning it, you h ave no idea all the shit that can be in a tank that has sat that long.
I dont feel like a sig today.
Old Jul 9, 2006 | 07:44 AM
jst4shw's Avatar
i got this thing runnin now,,, it was the fuel pump,,and the tank was nasty,,,,,,,,,,,
thanks for the help guys,,,
