MR2 Questions
OK. So I found two MR2's I REALLY like. One is a non turbo and the other is a turbo, I'm undecided which of the two I would like to own.
The non turbo one has 66k miles and is all stock except for supra rims, the turbo one has 123k miles on it and is all stock with some horrendous rims on it.
Having 132k on the motor a bad thing? I wanted to get back into Toyota by having a 3SGTE 6th gen Celica but I've always had a place in my <3 for MR2s.
Mazda 2 Forums
R.I.P. Pablo 'Fathead' Garcia - Love you man! See you on the other side!
R.I.P. Kevin 'Slo_Si' Gonzalez - You will be missed!
Mazda 2 Forums
Most of the Turbo USDM mr2s have high milage...buy the turbo and some rims...but check for oil leaks,timing belt wear,water pump failure,low oil pressure,blow by,turbo end play,check that the turbo impellor spins freely,if the car has ever overheated it's hard on the pistons and rods.If you can get the n/a cheap enough you can swap in a turbo motor easy enough given it has a manual tranny but that generally costs from $4000 to $8000.
http://xat-racing.ebizautos.com/detail.aspx?iid=1041211
go test drive a n/a then the turbo.
like christo said... dont let the mileage scare you, mine has 143k!!! and runs perfectly.
Torch Red SS 6 speed
Euro Red MR2-T 5 speed
2000 Si FS $3000 buy me! buy me! buy me!
Originally Posted by DBHMR2
i think xat has a celica there willing to swap for a 3sgte
Mazda 2 Forums
Mazda 2 Forums
Check the HFH !!!!
Hose From Hell
Hose From Hell
Hondata saves lives
Hondata saves lives
Built 3SGTE and 280WHP should never go in the same sentence
Hondata saves lives
Hondata saves lives
Jap Dan is my hero.
Mazda 2 Forums
Mazda 2 Forums
i dont get it?
