01 IS300 - v160 Swap Parts List
Just compiled the parts list for this swap. Please chime in if I forgot something(s). This is for a v160 6-Spd. into an 01 IS300 (auto).
-V160 Tranny
-All necessary shifter parts, tranny mount, cross member, fork, etc
**EDIT: Just to be sure, these parts would be out of a Supra (TT?)?
-Custom driveshaft
-Supra TT slave cylinder
-GTE flywheel
-Heavy duty clutch
-Clutch pedal assembly
-IS300 M/T master cylinder
-IS300 hydraulic lines
-IS300 M/T speedometer cluster
-IS300 M/T ECU and wiring harness
-IS300 M/T rear carrier
-V160 Tranny
-Custom driveshaft
-GTE flywheel
-Heavy duty clutch
fear is your only god
Why? Are you planning on turbo charging the car?
If so think about getting the LSD rear end as well.
Check THIS link. It might give you some other thing to think about.
FYI here is the parts list for a complete 6 speed swap with everything...
Copied from Supraforums...
Engine drive belt tensioner assy:
http://mkiv.com/techarticles/auto_t...tension_damper/
16620-46070 tensioner list 196.17 cost 145.07
16621-46010 bracket list 40.41 cost 29.89
16622-46010 arm list 19.26 cost 14.24
16602-46010 shock absorber list 62.56 cost 46.26
91511-g0845 bolt list .91 cost .68 x 2
90901-16001 stud list 2.09 cost 1.54
90179-08171 nut list .89 cost .65 x 2
90116-08348 bolt list .83 cost .62 x 2
90080-17242 nut list 1.37 cost 1.01 x 2
parts total : 242.92
Clutch parts:
90363-12002-77 pilot bearing list 8.76 cost 6.48
96152-00500 snap ring list 2.66 cost 1.97
90903-63001 t/o bearing list 65.50 cost 48.44
90560-50001 snap ring
90560-79001 spacer list 2.31 cost 1.71
90206-12006 wave washer list 1.57 cost 1.17
90520-75001 snap ring list 2.97 cost 2.20
31264-14060 spring list 2.97 cost 2.20
31231-14050 hub list 33.38 cost 24.69
31204-14060 fork list 65.16 cost 48.18
31234-14020 spring list 1.97 cost 1.46
31236-14030 support list 31.27 cost 23.12
90119-08079 clutch cover bolts list .46 cost .33 ea x 6
90119-10054 bolt list .86 cost .64 x 2
90910-02115 flywheel bolts list 9.72 cost 7.18 ea 8
13450-0W011 flywheel list 611.96 cost 452.53
Use your own supplied clutch cover and disc. See up-grade list at the end of this post for the TRD single disc or TRD twin disc kits.
parts total : 674.85
Transmission:
33030-0w212 v160 assy new list 5478.75 cost 4774.12
31123-14020 inspection cover list 29.84 cost 22.07
31121-14030 inspection cover list 36.18 cost 26.75
90080-11228 bolt list .69 cost .50 x 4
08885-01306 v160 oil qt list 47.62 cost 35.21 x 2
Transmission comes dry shipped, no fluid.
parts total : 4895.36
Clutch Hydraulics:
http://www.mkiv.com/techarticles/au...side/index.html
31470-14060 slave cylinder list 64.61 cost 47.77
90080-10055 bolt list .89 cost .65 x 2
31410-14310 master cylinder list 99.39 cost 73.49
90179-08237 nut list .91 cost .68 x 2
31481-14260 tube list 20.52 cost 15.24
96816-50335 hose list 24.86 cost 18.47
31484-24010 bracket list 6.69 cost 4.97
31482-14060 tube list 10.89 cost 8.06
90119-06406 bolt list .69 cost .50
96991-10080 clip list 1.20 cost .89 x 2
90119-06733 bolt list .54 cost .41
90080-11231 bolt list .51 cost .38
90461-08702 clamp
79191-00502 Castrol GTX brake fluid pt. list 3.75 cost 2.50
Braded TRD clutch hose available, see up-grade list at end of post.
parts total : 176.23
Transmission mounting/driveshaft
12371-46110 trans mount list 70.56 cost 52.18
90119-08770 bolt list .89 cost .65 x 4
90179-08159 nut list .89 cost .65 x 4
90201-11013 washer list .52 cost .38 x 4
90179-11017 nut list 1.51 cost 1.12 x 4
37100-14810 driveshaft list 675.26 cost 499.33
90119-10217 bolt list 1.51 cost 1.12 x 2
90105-12265 bolt list 7.63 cost 5.65 x 3
90560-12059 spacer list 4.12 cost 3.04 x 3
90179-12128 nut list .91 cost .68 x 3
TRD trans mount available, see up grade list at end of post.
parts total: 593.06
Shifter assembly:
http://www.mkiv.com/techarticles/au...6spd/index.html
33504-14130 shift knob list 103.63 cost 76.63
33511-14031 control shaft list 25.15 cost 18.60
33513-22030 yoke list 7.63 cost 5.65
33530-14442 93.5-95 short throw shifter list 126.44 cost 93.49
90301-11015 o ring list 2.92 cost 2.15 x 4
33531-14010 boot list 39.44 cost 29.16
90387-08134 collar list 1.91 cost 1.41 x 2
33555-14110 boot list 31.55 cost 23.33
33555-14100 boot list 9.83 cost 7.27
33556-14050 seat list 1.54 cost 1.14
33057-14010 bracket list 44.33 cost 32.78
33570-14070 shifter tri-pod list 96.77 cost 71.56
93381-16016 bolt list .85 cost .55 x 4
90179-08095 nut list 1.14 cost .85 x 2
90105-08200 bolt list .89 cost .65 x 2
91651-60835 bolt list .26 cost .20 x 4
90105-08076 bolt list .74 cost .55
90179-08233 nut list .91 cost .68
90250-06026 pin list 1.06 cost .79
90467-21010 clip list 2.61 cost 1.93
33546-22020 bushing list 14.15 cost 10.47 ea x 2
You can use the B & M shifter in place of the stock one.
parts total : 380.98
Console parts:
http://www.mkiv.com/techarticles/au...nnel/index.html
58261-14010 upper trans tunnel list 78.54 cost 58.08
58994-14010 console bracket list 6.74 cost 5.01
91651-60614 bolt list .94 cost .71 x 2
58804-14060 shift bezel w/boot 93.5-96 list 140.44 cost 103.85
58804-14100 shift bezel w/boot 97-98 list 140.44 cost 103.85
58280-14080 boot/plate assy list 23.81 cost 17.60
parts total : 168.36
Brake pedal:
47101-14230 brake pedal list 49.67 cost 36.88
31321-14020 brake pedal pad list 3.23 cost 2.39
You can re-use the misc parts on the brake pedal bracket assy.
parts total: 39.27
Electronics:
83242-1u310 6spd tach list 118.75 cost 88.19
89661-14521-84 ecu 6spd obd1 93.5-96 list 1111.50 cost 913.53
{includes 100.00 core charge]
Call for obd2 ecu pricing.
If Dusty @ MVP has them available you can use the TRD 10K tach.
http://www.supraforums.com/forum/sh...threadid=181819
parts total : 1001.72
Clutch pedal:
31311-14120 clutch pedal list 42.18 cost 31.32
90541-06036 cushion list .83 cost .62 x 2
90949-03011 spring list 1.93 cost 1.43
90386-13015 bushing list 1.37 cost 1.01 x 3
90949-03013 spring list 11.40 cost 8.47
31321-14020 pedal pad list 3.23 cost 2.39
90101-10015 bolt list 1.00 cost .74
90387-10003 collar list 4.54 cost 3.36
31353-14010 holder list 3.34 cost 2.47
90240-08006 pin list 1.71 cost 1.27
90386-08010 bushing list 5.37 cost 4.00
55107-14140 support assy list 69.76 cost 51.80
91655-60630 bolt list .60 cost .47
90119-08a22 bolt list .71 cost .53
96160-00600 e ring list .63 cost .47
94512-01000 washer list .63 cost .47
94110-51000 nut list .60 cost .47
90386-05017 bushing list 1.91 cost 1.41
90206-08001 washer list .83 cost .62
90468-16142 clip list .72 cost .53
88280-14030 switch list 16.60 cost 12.32
84520-24010 switch list 38.64 cost 28.68
94120-41000 nut list .60 cost .47
parts total : 157.96
Rear differential:
http://www.mkiv.com/techarticles/au...tial/index.html
41651-14010 mount list 81.14 cost 60.00
41110-14780 6spd lsd diff assy list 2563.80 cost 1895.85
79191-00672 75w90 Castrol gear oil list 13.95 cost 10.15 x 2
42340-14140 lh drive axle list 393.49 cost 290.97
Diff comes dry, need to fill.
Up-grade to TRD LSD UNIT see list at end of post.
parts total : 2267.12
GRAND TOTAL:[ for those of you who don't know how to use a pocket computer or are to lazy]
242.92
674.85
4895.36
176.23
593.06
380.98
168.36
39.27
1001.72
157.96
2267.12
_______
10,597.83 SHIPPING NOT INCLUDED
UP - GRADED PARTS LIST:
00602-31201-010 TRD single clutch kit list 655.00 cost 595.00[disc,cover, t/o bearing]
31000-ja800 TRD twin disc clutch kit list 1875.00 cost 1595.00
[flywheel, cover , plates, discs]
90947-ja800 TRD clutch hose list 61.60 cost 54.12
12371-ja800 TRD 6spd trans mount list 79.80 cost 70.11
41301-ja800 TRD LSD unit list 924.00 cost 811.80
90366-54014 bearings list 47.64 cost 35.23 ea x 2
90311-45013 axle seals list 22.35 cost 16.53 ea x 2
I do include the parts pictures of each area as needed and all parts are shipped labeled in their own seperate bags.
This also does not include any other items that you might need.
For example exhaust pipe gaskets, misc items that you might loose, break, or are already missing from your car.
Most items in stock. But can take up to 2 weeks till they ship out to you.
Shipping charges not included and are based upon what is ordered.
Don't call me and say" I need everything"!!!!!
I WILL SHIP YOU EVERYTHING!!!
Figure out what you want and don't want. MAKE UP YOUR LIST!!!!! Copy and paste the items needed to an e-mail. Don't call me and tie up our time by giving me every part number over the phone.I already know the part numbers.I'm NOT a mind reader. If you are collecting used parts for this swap, find them FIRST then make up your list.
AS for you NA MKIV owners:
You should not be doing a TT swap or a 6 speed swap on your cars!!!
This is way toooooooo costly for you, not to mention the time involved.
MY advise to you is: sell your car, and BUY a TT MKIV with a 6speed. IT WILL BE CHEAPER IN THE LONG RUN.
Clutch parts:
Transmission:
Clutch Hydraulics:
90461-08702 clamp
parts total: 593.06
Shifter assembly:
Console parts:
Brake pedal:
parts total: 39.27
Electronics:
Clutch pedal:
Rear differential:
242.92
674.85
4895.36
176.23
593.06
380.98
168.36
39.27
1001.72
157.96
2267.12
_______
'96 Supra NA-T
"I'm not driving fast, I'm flying low..."
'96 Supra NA-T
thank you for the info
The plans for the car are still being drawn out, but this tranny swap is something I wanted to research a bit more. Still exploring different options with the motor setup at this point in time.
Xat has done a 6 speed in a turbo IS300. Maybe they can shed some light on the subject.
Part of:
Wangan Midnight Maximum Tune 2 sedan expert.
APXRO: JZX100 Chaser "Odaiba Romance" 815HP/DG B1 2 overhauls. secret weapon
PM!: UCF10 Celsior "Jealousy" 810HP/DG B3 0 overhauls. vs battle car
Part of:
