purchasing usdm 2j for sc300 swap?
where can someone locate one of these? or are they stuck with the jdm 2j?
Sarasota's Premier Automotive Community
Guest
Posts: n/a
Sometimes Jim @ Turbo Toys has some... or you can ask this question on the Florida section of Supraforums if you want a better response. Expect to spend about $6K for the whole swap... another alternative is to turbocharge the motor that is already on the SC300 for cheaper and make more power. Both of them motors are basically identical, aslong as you lower the compression on the one in the car now.
+1
You arent going to get much for 6,000 from a swap. 6,000 into an existing motor is alot easier and cheaper. Do as kirk says and go to his website, loads of info. Hes personally converted his NA 2jz to a NA-T.
Its very straightforward. Pistons (for compressions) as well as rods if you want anything insane. Injectors, fuel system and of course turbo/oil lines and intercooler. There are other little things however for the most part its going to cost a whole lot cheaper than swapping a STOCK 2jzgte in. Everywhere Ive looked has said either turbo the existing car or look for a turbo model, in this case turbo the existing motor.
Jims alittle pricey but hes honest.
"so persuasively did they talk; and yet there is hardly a word of truth in what they have said."
Plato, Apology
"On life's journey faith is nourishment, virtuous deeds are a shelter, wisdom is the light by day and right mindfulness is the protection by night. If a man lives a pure life, nothing can destroy him."
Buddha
Plato, Apology
Buddha
