ae86 starting problems
Try to check for spark straight out of the coil, if good, go through Slash's list, if not try the following...
The ignition system is pretty simple. If you have a known good dizzy and coil, your ignitor and or wiring are the only two to worry about. The 4age black top ignitors will operate with or with-out a functioning engine computer.
If you have the 4 pulse sine wave from the pick-up coil in the dizzy to the ignitor, a good power from the black with orange wire from the round five wire connector, a properly powered coil with a good trigger wire from the ignitor, and a properly grounded ignitor, then the engine should have spark or the ignitor is bad. I hope this helps...
I have a spare ignitor if that turns out to be the problem.
Part of:
Wangan Midnight Maximum Tune 2 sedan expert.
APXRO: JZX100 Chaser "Odaiba Romance" 815HP/DG B1 2 overhauls. secret weapon
PM!: UCF10 Celsior "Jealousy" 810HP/DG B3 0 overhauls. vs battle car
Part of:
Originally Posted by sidehappyside
well i bought an aw11 dist. and it still doesnt work. I dont think its my dist. anymore. its something else! err
You bought a used dist..... thats not saying much of anything towards eliminating a variable in the equasion...
I dont feel like a sig today.
Problem solved! Intake cam jumped a tooth.
Motor is okay but not great. At least it drives now.
Part of:
Part of:
