4age cam gears???
Old Apr 21, 2005 | 07:04 AM
thereturnofdark's Avatar
Obama made me Republican
Default 4age cam gears???
hello everyone i got a deal on some decent 4age cam gears. i was wondering if they would fit on a 4afe?
Old Apr 21, 2005 | 09:43 AM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
Maybe...it all depends on how different the F heads are from the G heads.
ASE: Brakes
Old Apr 21, 2005 | 12:40 PM
distroyFL's Avatar
uhh... don't quote me on this but i think the 4afe cams are gear driven. i.e... gears mesh inside the head, so if this is true, which im pretty sure, but not 100%, cam gears arent going to do anything.
Old Apr 22, 2005 | 08:18 AM
oh ok, i was figuring i'd try it. sicne the 4age is a more powerful engine i figure cam gears from it might give the engine a little power thats being stolen away from it when i turn on the ac or something. i can get them for like 10 bucks in very very decent shape. i would ask someone at toyota but all i get is "we at toyota recommend that you do not modify the car from factory specifications"
Old Apr 22, 2005 | 12:03 PM
Slash's Avatar
THE HAMMER
Cam gears dont have anything to do with the AC.....
Listen.. Just keep your car stock... please just buy another car to do things to and leave the most reliable car in the world alone..
I dont feel like a sig today.
Old Apr 22, 2005 | 01:56 PM
distroyFL's Avatar
yeah i think you have the function of cam gears a little distorted. cam gears are slotted with set screws so you can degree them positively or negatively to advance or retard your cam timing. they wont give you more power, but they will change where in the rpm range your power may kick in. well, i suppose maybe a fraction of power, but thats beside the point. does the timing belt on the 4afe slip over one cam gear or two? cause if the belt is just driving one cam gear then the one cam is being driven off of the other by a gear inside the head. so really you could only put one adjustable cam gear on there and it wouldnt really do anything. you could just dial them in differently and it would perform the same function. and where are you getting these gears for 10bucks???
Old Apr 22, 2005 | 04:48 PM
thx appreciate the info. i am just content with the fact that i learned something new without the typical tr flaming. appreciate the intelligent feedback
Old Apr 22, 2005 | 06:38 PM
distroyFL's Avatar
nikon, when you take off the timing belt cover does the belt go from the crank pulley to one or two cam pulleys? i am curious myself now. like i said before, even if it is belt driven, if there is only one cam pulley then whichever cam is being belt driven, is driving the other cam via gearing. its a common DOHC setup.
