*big News For Mr2 Fans*
Originally Posted by hachibill
so if its a different ohm, or signal strength you can change that in the rom tune.
I dont feel like a sig today.
Well, if they hold true to what they said bout developing a Gen3 solution soon, then I think its a major step for the owners of those motors.
Originally Posted by MR2driver
In the end it is still a shitty flapper door. Find a way to have the Gen 3 ecu to work with a Gen 2 engine, this is a better waste of time IMO.
some ppl have tried rx7 maf chips and stuck them in the stock housing on the 3s but it has ALWAYS ended in motor death. whether or not this can be attributed to the maf or not is unkown but its a hell of a coinsidence. Now... the reason we cant use Other mafs completely is bc toyota in all there wisdom designed our mafs voltage to be reversed from that of the mainstream. Dunno why... sux tho.
Thomas
90 Celica 3sgte swap (57 trim ct)
90 MK3 Supra Turbo *in ICU*
Thomas
ok, why aren't they compatable? care to elaborate why? has anyone even tried? maf upgrades should work no matter what style of maf it is, but the only way to get them to work properly is to have the rom tune set up for it. so if its a different ohm, or signal strength you can change that in the rom tune.
I honestly do not know about using with a new rom board such as a sard patch or something. But if your going to that length... then as I said... y not ditch the bitch completely?
Thomas
Thomas
Yea, I agree with mr2 driver. If your gonna do it , make it complete. Even to swap to a 3rd gen ecu ,harness,map sensor and Ignitor ect.ect. into a 2nd gen will cost you as much as a full stand alone . Already thought of this . But it would be good on a full full 3rd gen where you could really make a difference.There is really no easy fix to get rid of the afm.Alot of people will by it though because thats all they care about anyway, is a somewhat reliable 300 hp .
still didn't answer my question, i am talking about useing TOYOTA maf's, not mazda. so if they can rom tune the 2nd gen, then you can get a little more power out of a bigger maf from a n/a 7mge or the 5mge. i know the flapper maf's suck but i am still in the right so either go stand alone or get off the pot. now what about rom tuning 7mgte ecu's?
Disney Man
Jun 24, 2002 09:14 PM
Scott
Jun 23, 2002 11:45 AM
