20v help
Old Aug 30, 2004 | 10:33 AM
deez92's Avatar
mullet racing
Default 20v help
where the hell do i cut the head for the water lines? thanks dee.
Great accomplishment only comes with great risk. I’ll accept the crippling, gut wrenching disappointment of risking all, and failing, but only by putting my whole heart and soul, my whole being into something, will I have the chance to walk among the stars.
Those who risk nothing, those who live their lives in fear, will never have that chance.
Failure is not a sin. It’s being too afraid to even try, that is a sin.
Old Aug 30, 2004 | 10:58 AM
deez92's Avatar
mullet racing
why can't i just cut the thermostat housing?
Old Aug 30, 2004 | 11:04 AM
deez92's Avatar
mullet racing
Old Aug 30, 2004 | 02:51 PM
aphxero's Avatar
"the apex hero"
Take a big drill and go through the side of the head. Theres a square hole behind the exhaust ports for a heater line. Just go through there and drill a hole through that wall between the 2 water passages. And about the thermo housing, to do the coolant reversal you have to run the 16v water pump. You have to block off the back of the head. The whole reason for doing this is so you dont have to cut a big hole in your firewall.
If you want any more info ask me or marksaccord95.
Part of:
Wangan Midnight Maximum Tune 2 sedan expert.
APXRO: JZX100 Chaser "Odaiba Romance" 815HP/DG B1 2 overhauls. secret weapon
PM!: UCF10 Celsior "Jealousy" 810HP/DG B3 0 overhauls. vs battle car
Old Aug 30, 2004 | 03:12 PM
deez92's Avatar
mullet racing
i'm trying to do the same as mark did. so i just cut from one hole to the other(in the first pic)? and then make a block off plate? thanks dee
Old Aug 30, 2004 | 09:22 PM
aphxero's Avatar
"the apex hero"
yeah thats it for the back. Where do you think mark got the idea?
IM me i have a good .pdf about how its done.
Wait a sec! This IS going in an ae86 right? Because in any other layout you can just do it the normal way.
Part of:
Old Aug 31, 2004 | 03:04 AM
deez92's Avatar
mullet racing
pm sent
Old Aug 31, 2004 | 08:47 PM
marksaccord95's Avatar
TR Registered Member #5
u dont drill thru the jackets with a bit. get a cut off wheel and cut the space between the 2 jackets on the back of the block so it looks like a rectangle when done. cut the thermo housing in 1/2 and use that as the flange, weld a piece of metal onto the cut housing and use some sealant.
for the side u gotta extend the neck down
run a inline coolant temp sensor, like the HKS 1 pictured and connect that to the top of the radiator. then the bottom will connect to the 16v water pump, gotta modify the outlet on the pump slightly. u wont have a thermostat, but thats fine, it just runs a little shitty when cool but when warm it runs at a cool 169F
http://www.floridaracing.org
