Art of Brake Boosting
auto is simple, left foot on brake and right on gas, build boost.
6speed you need to heel and toe.left foot on the clutch and right on the brake and gas. put enough load on the engine at a good rpm to build some boost then let off the brake and go.
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
Originally posted by n2ocamry
wow
i learned that when i was 12, and im not kidding
also down shift helps
wow
drew
NEED PARTS WTB: Turbo Timer, TIAL 38MM+ WGATE, Race Manifold, etc
NEED a FPR installed!!
White 97' kouki RIP
Green 96 TURBO
White 97' kouki RIP
Green 96 TURBO
downshift....wtf is that.
. I'm more a man and ride that bitch out in fifth.
drew
. I'm more a man and ride that bitch out in fifth.drew
White 97' kouki RIP
Green 96 TURBO
White 97' kouki RIP
Green 96 TURBO
actually you shouldnt need to be pushing the clutch in. Carlos just get to your desired roll speed so lets say 60mph. Once you do that make sure you are in the proper gear where you will have the most usable powerband. Then use your left foot to begin pressing on the brake pedal while at the same time giving it enough gas to keep you at your desired speed. Looking over at your boost gauge you should be able to see yourself starting to build boost. Keep pressing down on the gas until you get to about 75% to WOT while still holding the brake with your left foot to keep you at 60mph...let go of the brake pedal and hold on
It's stock, I swear!
Originally posted by agent89
i was talking about a launch.
Besides for launching you shouldnt need your foot on the brake if your 6spd. Just rev it and slip that clutch.
BTW hows the car running? Havent seen you around at all.
