1993-1997 Gs300
Originally posted by suprapimpa
I've seen a GS300 with a 2jzgte swapped in somewhere. Hell of a sleeper, go for it if you have the money
350 would be enough, maybe 400..
It would be cheap to just make log manifolds for intake and exhaust just to GITTERDUN...
I dont feel like a sig today.
Guest
Posts: n/a
Originally posted by Twisted
that wont work because they are two completely different heads and the turbos will not bolt up. You would have to find a GTE head and the turbos and other shit. Then you still have the GE block which doesnt have the oil squirters and is higher compression etc..
That is why when people come on supraforums asking about buying an NA supra and turboing it people always give them the answer that it is much easier to buy a turbo model first but that is also because of the better brakes, and everything else.
You can also NA-T this with a new kit thats out from boostlogic, it has a tubular manifold etc.. only thing is that its for an NA supra or sc300 so i'm not sure if it will clear everything in the engine bay of the GS. Might as well take a look though. www.boostlogic.com
Boost Logic is going to take about 4-6 weeks after I place my order to get my kit finished and sent... but I will be the first Supra with their kit.
Id rather not do a kit, the price premium is way up there just casue its a "supra" ooohhhh....
hopefully I can stay in the 2.5-3K range for my pieced tougether kit
FYI - That tranny will not hold 400hp, sorry.
If you look in the St Pete Times there is a 93 SC300 5 speed for sale $6900. Same engine, better tranny, just upgrade the clutch.
'96 Supra NA-T
"I'm not driving fast, I'm flying low..."
'96 Supra NA-T
Originally posted by SupraKid
Heads are same just diff exhaust/intake pattern.... I have the advantage of the oil squirters
