tech help needed ASAP
Old Jan 25, 2004 | 05:15 PM
GearGrinder's Avatar
ridin high
Default tech help needed ASAP
just got this 88 supra turbo,
it needed alot of work.
we replaced the hg, alot of hoses (car would barely run when we got it)
we did a compression test and everything was fine but cylinder 3 has 0 compression... so we did the hg then put everything back togeather....
now we still get 0 compression in cylinder 3 and the car wont turn over...we checked everything, getting air, and fuel, and spark
what can be the cause of this???
thanks for the help
Own an APBT? visit... www.mypitbullpro.com
Old Jan 25, 2004 | 07:14 PM
agentAndy's Avatar
more class than college
warped head, srtipped threads in the spark plug hole, fubar'ed valve seats.
was the cylinder wall all tore up on #3? did the piston look to be in good shape? were the valves sealing to the head?
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
Old Jan 26, 2004 | 07:41 AM
ridin high
valves were fine, cylinder 3 was fine, piston was fine everything was perfect,
i would just crank and try to turn over.i was told that it might not be getting spark?
Old Jan 26, 2004 | 09:46 AM
ridin high
If anyone knows these motors and thinks they can help out i would be eternally greatfull!!
let me know
Old Jan 26, 2004 | 01:00 PM
agentAndy's Avatar
spark doesmt matter with the zero compression on 3. ther is a serious problem there. pull a plug and keep the wire on it and hold it against the block(hold the insulated cap, not the plug it self) and have someone turn it over. check for spark.
Old Jan 26, 2004 | 01:01 PM
agentAndy's Avatar
this should help a little.
SUPRA TSRM
Old Jan 26, 2004 | 01:04 PM
ridin high
how about this.... $300 to anyone who can fix this car.... the compression AND getting it running??
lol
Old Jan 26, 2004 | 03:53 PM
agentAndy's Avatar
wish i had the time.
