Supra/SC300 help
Ok, my plan is to acquire one of these two cars and obviously modify the living shit out of it...
I was wondering what may or may not be a wise decision..
Purchase an N/A supra and boost it/build the bottom end even
Purchase an N/A supra and SWAP the GTE and the 6 sp into it
Purchase an SC300 and turbo that sucka
the same an SC 300 and SWAP whatever may be possible... be it the 6 sp and or gte for durability
What is going to be the easiest and most "cost effective" solution so to speak.. Im not saying im worried about the money so much, but Im not too sure on where to go, and if it is going to be pointless to just mess around with the N/A cars going boost, i would hit on the TT 6 sp....
thanks
Mark
thanks
Mark
95 Supra Turbo 6 speed
11 SWP STI sedan
11 SWP STI sedan
ahhh.... thanks mike, and thanks for being a smartass
im not copying you, i keep watching redline 3 and that damn gunmetal colored supra is so hot
shit...
besides, i want an MKIV, not a 3
and i DONT like crome wheels
or is that CHROME
shit...besides, i want an MKIV, not a 3
11 SWP STI sedan
11 SWP STI sedan
AFAIK, a 2jz-gte clip will cost you around $5k. You can spend that money to turbo the NA and get ~400 rwhp. If you want more than 400 rwhp, then you probably want the 2jz-gte rather than rebuilding a 2jz-ge. IMHO.
You need to grab ahold of that line between speed and chaos, and you need to wrestle it to the ground like a demon cobra.-Talladega Nights
na motor is good for 600ish at the wheels with a fatter head gasket, if you are trying to go further than 550ish safely, GTE swap....the W-58 i the n/a might be a possible weak point, ....wonder if theres a way to get an R-154 out of a MK3 turbo to fit in an MK4, much more cost effective, if not, you either need a built auto, or gotta bite the bullet and purchase the Getrag V-160 6 speed, and it is NOT cheap
Poppa J. Smurf
Poppa J. Smurf
Money is speed, how fast do you want to go?
I think i will wind up with an MKIV TT just for simplicity's sake... all the "weakness" isnt too bad, but hell, if you have a turbo supra, and you ARENT above 500 rwhp, you havent spent enough money on turbos
and now ive got a hook up w/titan motorsports
11 SWP STI sedan
11 SWP STI sedan
thanks
Mark
thanks
Mark
11 SWP STI sedan
11 SWP STI sedan
