mk2 supra swaps.....
Guest
Posts: n/a
ol right
what was the dudes name with the 7m in his mk2? like chris or somthing....he does run his mouth alot but he knows his mk2s...u know his name or how to get ahold of him? i dont work with him anymore
any other info for the mk2 let me kno
so....what exactly is involved with this, wiring harness/ecu, motor, clutch/tranny, and be done w/ it...can a Mk3 rear end be swapped in, i know the MK2's dont have the strongest of rear ends..
Poppa J. Smurf
Poppa J. Smurf
It will basically drop right in . You can either bolt the 7m manifold on the 5M and boost it till it blows after you notch the manifold . Or just drop teh entire 7M-T motor in and wire it up nicly with a R154 . The MK2 Supra's rear is strong enough .
Fuck the Flag and Fuck you
If your going to post , please fucking think before you start talking out of your ass !
Toyota motors rock but their rear ends and tranny's arn't the strongest. I've busted 2 rear ends and atleast 4 trannys. I know the r154 is stronger than a w58 but you will spend less if you build a w58 for ultimate strength. so if your going stock use the r154 but if your rebuilding go with the w58(cheaper and more abundant)
