JZA70 brake cooling ducts...
I saw a set on Ebay, it went for about $150, and theres some on there now. last time i checked, they were about $75.
im just wondernig, if theyre supposed to bolt straight up to a MA71 or if it how it mounts up. i dont think ive actually ever seen any installed on the car..
heres some that they just put up for sale JZA70 Brake coolers
i dont know if they actually duct air directly to the rotor or just direct air to the vicinity of the brakes...
thast not a Turbo A, is it? at least that wing is beign used for what it was designed.
I knew youd see the light and come back to MK3's... once you pop, you cant stop. like a bad habit you cant quit. ehehe
Guest
Posts: n/a
I like MKIV alot better...... drive an MKIV then get in your MK3.... its like back to the future, you feel like you went back in time like decades
And yea thats a Turbo A.... I'll be gettng a black 91-92 probably for a 1JZ swap to build a nice show car like the one I pictured on the other post. For now I want to finish my MKIV.
yea, thatll be nice... it would be cool to do a straight TurboA conversion... id actually like to see RHD too. Id be more than willing to help out w/ my welding skillz. if i have the right tools, i can make anything happen... you gota admit, that would be the coolest.
Guest
Posts: n/a
I have a Turbo A decal for sale if anyone wants it.... OEM and never used. I also have the side stickers that goes on the Turbo A doors that has the Turbo A logo
I was planning on making a Turbo A replica with a 1JZ (since they are cheaper than 2JZ)... I might still do it, only if I can find a clean black MK3, 91/92
theyre out there. how much were you expecting/plannin on paying for one?
besides, you cant just slap on TurboA badges... you should keep them and use them after you do your 1J conversion... then you will have a TurboA clone... which is more legitimate than the next guy who slaps them on his 7M powered MK3... or worse yet, a 7MGE powered MK3... :o
