Do not expect an immediate reply.
While we view your requests, we may or may not reply immediatly. Some requests we may need to review with the entire staff, while other requests may warrant support from a large group of users before immediate action can occur.
Some suggestions:
*) If you are applying to be a moderator, please provide as much detail as possible. For example: What forum you would like to moderate, secondary forums you would like to moderate, why you would make a good moderator, experience moderating, etc. The more you provide the better your chances. If you simply post, "I wanna be a moderator", it will be ignored.
*) If you suggest someone to be banned, please supply links to offending posts.
*) If you encountered an error, please provide as much detail as possible.
*) If you are going to make a remark on something you believe to be a negative aspect of the site, please also provide a viable solution to your issue as well.
The goal here is to provide DETAIL DETAIL DETAIL to make our lives easier, and to keep our guessing at a minimum.
Some suggestions:
