Subaru Tech All We'll Drive
Pressure Testing(ASK Mastro & TR.com)
Old May 19, 2003 | 01:39 PM
lstepnio's Avatar
1337 H4x0r
Originally posted by Billy
They come with a larger washer to put in to hold more tension on the spring. It is only a matter of undoing the 4 allen head bolts on top and swapping it out. Mine holds fine at 18.5psi on a larger turbo flowing alot more cfm.
I don't think mine came with such a washer. I didn't see it mentioned in any of the instructions either.
Old May 19, 2003 | 07:56 PM
Bone's Avatar
Blingo!?!
sell it get the stealth it also has the adjustable spring rate which is nice, and hippy boost isnt directly related to throttle position its the load the engine is under, more load = more exhaust = more boost, (a simpliefied way of saying it but yea thats it)
20TenProductions "Born to lose and Destined to fail!"
Old May 19, 2003 | 10:37 PM
hippy's Avatar
Default hey
that still makes no sence to me....more load doesn't mean more exhaust even though it might be easier to get boost when you are in higher gears. It makes more sence to me that the transmition is putting more backpressure on the intake and that is what makes the boost more consistent in higher gears. That would also make sence as to why a leak would affect your car more in a higher gear. those are my thoughts on the subject, but I'm probably wrong. peace,
hippy
Old May 20, 2003 | 03:56 AM
M249SAW's Avatar
Firemedic / Local 4420
The early GFB Hybrid BOV came with a thicker washer due to some problems with the spring.
All of the GFBs we have sold in the past 4 months or so already come with the thicker washer installed.
Kyle
Old May 20, 2003 | 05:39 AM
lstepnio's Avatar
1337 H4x0r
I replaced the IC/BOV gasket last night but I really only had a chance to make a run or two so it's hard to say if it's really better.
I did notice that while engine is idling the BOV piston is bouncing a tiny bit but I dunno if it's normal or not.
-luke [www.majjix.com]
Old May 20, 2003 | 08:29 AM
  #18 (permalink)
lstepnio's Avatar
1337 H4x0r
I took it for another spin at lunch and it still doesn't seem to be right. The only other thing I can think of before I remove the BOV is try resetting the ECU as I did not reset it when I installed the BOV.
Old May 22, 2003 | 04:32 AM
  #20 (permalink)
Tits McGee's Avatar
is cooler than you
Once you replace your fog lamps, that'll fix everything!
