Subaru Tech All We'll Drive
I need a used WRX center differential.
Old May 16, 2003 | 07:54 PM
Sam@Coastal's Avatar
Does not race from a roll
Default I need a used WRX center differential.
Anybody know where i might find one?
www.coastaldyno.com
Smackin down LS1s since 99', LQ4s too...
Old May 17, 2003 | 11:20 AM
any idea who may know what years interchange?
www.coastaldyno.com
Old May 17, 2003 | 04:06 PM
cool, id like to have one to interchange at the shop. the way it plays out to me is all the torque will go to the front wheels and at least allow me to load the car on the dyno to get accurate a/f readings. and after looking at the comparisons it looks like only about a 2hp difference between an AWD pull and a converted fwd pull. thats according to the info i got from a guy at MD where I bought my dyno who actually has a 2.5RS and has done the back to back tests in house on both an AWD and 2WD unit. I know its a pain in the ass to switch the diffs out, but i figure i'll only really need to do it once to get the tune right. and I usually pull all nighters on the dyno when i really get focused so i would imagine renting an AWD dyno for 24 hours would be a bit on the pricey side.
www.coastaldyno.com
Old May 17, 2003 | 04:31 PM
hippy's Avatar
Default hey, I don't get it
do you not have a center diff or what? I don't get it...If you're just tryin to get your car to be front wheel drive, there is a fuse in the engine compartment fusebox that says FWD. It is empty, if you put a fuse in, your wrx becomes front wheel drive. I hope that saves you time changin out your center diff. Peace,
hippy
Old May 17, 2003 | 06:58 PM
I thought that was only for the automatics or the wagons? can someone clarify?
www.coastaldyno.com
Old May 18, 2003 | 05:40 AM
hippy's Avatar
Default hey
from what I know it works on all subarus that are autos, and ones with turbos. The FWD socket is there, you just gotta plug in the extra fuse(I think the green one)....I think they made it that way in case you get a flat and have different size spares, so you can put the good wheels on the front and not screw up your diffs. Anyways that all I know, other than the fact that if you don't need a center diff, you shouldn't get one Anyways have a nice day,
hippy
Old May 18, 2003 | 06:42 AM
Bone's Avatar
Blingo!?!
how can a non elcec mech center dif be controlled by a fuse, since its using fluid to determin the tq split not elec, talking about manuals for my reply
20TenProductions "Born to lose and Destined to fail!"
Old May 18, 2003 | 07:14 AM
hippy's Avatar
Default good question
hey bone,
I have no clue, but I wanna go put the fuse in and try to peel out a bit It says in the manual that I can do it, so I think I can Anyways, I was just reporting what I read, not what I tried, I figured it was the truth though. peace,
hippy
