Subaru Tech All We'll Drive
Rear Struts
Old Apr 5, 2011 | 07:28 AM
89crxsir's Avatar
Default Rear Struts
I've owned this 04 sti for a couple of months now and love it! The rear struts clunk, are they bad or is this normal?
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Old Apr 5, 2011 | 07:40 AM
jcssti6265's Avatar
TampaBayTunedPerformance
you sure its the struts, there are a couple of itbs for the water cooler moving that can sound like strut knock, and for the subframe/diff shift knock. water tank there is no fix for the shift knock, a set of bushings or whole rear kit will clear that up. May be the struts but usually its not
Old Apr 5, 2011 | 07:45 AM
89crxsir's Avatar
The water tank is tight. the car has 102,000 miles on it, and they were never replaces. I got the service records from the dealer. All of the bushings look good as far as i can tell
Old Apr 5, 2011 | 09:54 AM
jcssti6265's Avatar
The bushing may be tight but have to much play, its very common, search it you wil see. I've seen a lot of these cars wit much higher mileage than that with original struts 102 isn't that high.
Old Apr 5, 2011 | 12:36 PM
mantra1's Avatar
Shaggin' Wagon IV
'04 Sti struts are know to clunk. There is a write up on ScoobyMods that explain how to fix this, but it means taking the assemby appart.
http://www.scoobymods.com/04-sti-rea...ing-t9972.html
If your going to do that, might as well get a new set of struts or some nice coilovers.
2011 TSX Sportwagon
Old Apr 13, 2011 | 01:08 PM
89crxsir's Avatar
I'll have to look in to both problems more in depth.. Thanks
Old Apr 14, 2011 | 05:15 AM
00lgt's Avatar
There fairly easy to regrease just follow the write up and you will be good
jst4shw
Old Apr 14, 2011 | 12:49 PM
89crxsir's Avatar
I do have a much better spring compressor than the one in the write up. I'll have to confirm it's the struts clunking over bumps and stuff
Old Apr 15, 2011 | 03:21 PM
00lgt's Avatar
I've never needed a spring compressor but should make it a lot easier if your by yourself and I read somewhere that the Mobil 1 red grease was recommended
jst4shw
Codeine Fein
For Sale/WTB Honda & Acura
11
May 11, 2008 08:06 AM
GSL_SE
5
Jan 4, 2008 04:14 PM
Tom N
Jun 16, 2004 02:33 PM
