Got my car tuned
Childs play 110lb/min son!
Dude I had to spray a wet 40 shot with the 42r.....can't imagine bigger. Well maybe i can....hrm. Na my goal is low 10s in my street car.....a 55R would net 12s......ROFL
Drunmann Tuning's Scoob: 2.55 liter-6spd swapped Bugeye, fully built w/280 cams and a rotated Precision-6266
DD: 2010 MazdaSpeed3: Fully bolted and tuned
Drift Missile: S13 DOHC swap, welded diff = slidetastic
Bicycle: Kawi 636R.
Bicycle: Kawi 636R.
On what car?
It's a bugeye.
Couple bolt ons.....lol
Bicycle: Kawi 636R.
Bicycle: Kawi 636R.
hta 35r and the 62/62 are both capable of 600+. There are cars making 700 whp+ on stock intake manifold. Actually Ron at axis made 700whp on stock sti heads and mani if my memory serves me correctly.
What did you run with last years setup?
550/550
STi heads > WRX heads
An intake mani will make the biggest difference when close to head efficiency. I'm not arguing semantics with you about who made what and i won't argue that claim because anything is possible with the right setup.
From what theory tells us about what a STi head will (bench) flow is that 650hp is about it without extensive modification, alternate fuels, or improving volumetric area for moving air, or making the head plain more efficiency.
As the new build progresses it's getting a lot more expensive.
The last motor i could only get about 530s out of her. Turns out the quench area and comp ratio weren't ideal and it was really prone to knock so i couldn't run shit for timing. It's under the knife again with some custom quench pistons and lowering the comp a cunt hair.
600+ is a big task....a lot say it's easy to do, but they're usually owners of shops. This is my private weekend car. I'm not sold on ridding of the 6262. I definitely don't want a HTA35R.
I might try the PT and if its no bueno then teh HTA86 is looking mighty fine.
Bicycle: Kawi 636R.
Bicycle: Kawi 636R.
Quench area is piston surface area in relation to how it compresses air against the head. It was at 9.1-1.
I went increase compression to help the little 2.5 to spool the turbo...little did i know the internal setup wasn't up to par.
Nope didn't even bother taking it to the track. It was broken in, running decent, tuned, parked it right back in the garage, and then started tearing it apart later that week. I was so heated about it.
I would say even my old old setup with the stock EJ257, Rex heads w/ cams, and a FPRed would've taken it that setup to 120mph. The lag on the last setup was just unreal and plain dumb. I paid 6k more for a slower setup sweet.....
When you're rolling and hit antilag 3-step (FFS) in 2nd gear and slip off the clutch while holding boost and fall out of boost at 5500rpms there's a problem. hahaha
Bicycle: Kawi 636R.
Bicycle: Kawi 636R.
