p0457
im sure its broken anyways from your boost levels... and it literally takes 2 mins so its not a waste.. have you ever boost leak tested your car?
turbos will compensate to hit target boost doesnt mean you dont have a boost leak though... $5 says you have at least one even if its small
no just saying you should always make sure you dont have a boost leak especially before you get a tune
lol the only codes I'll do that is for my rear o2 sensor and tgv's. Other than that, if you got a cel, there's a reason for it. Whatever my reason is, its causing a lean issue at idle.
Coyote
Coyote
You will see a decrease in fuel efficiency. A certain percentage of fuel in every tank you use will evaporate and if you vent the evap line to atmosphere instead of the IM, it will be wasted. FWIW, with my "small" leak I am seeing 1-2mpg less per tank.
do you have proof of this? because all it is is fumes
