Subaru Tech All We'll Drive
restrictor pill issues....
Old Jul 31, 2009 | 02:40 PM
blacksti's Avatar
DudeMan
Originally Posted by chome
If you don't use the restrictor pill the car will overboost not underboost.
Well at least you found the culprit.
wrong...
the smaller the hole the more pressure it will build causing you to over boost
taken from cobb
If a restrictor pill with a smaller hole than .052” is used then the turbo will over boost which can cause severe engine damage. If a restrictor pill with
a larger hole than .052” is used then the vehicle may not be able to hit its boost targets.
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Jul 31, 2009 | 04:03 PM
chome's Avatar
Will sleep for food.
I stated without the restrictor pill the car will overboost....
Old Jul 31, 2009 | 04:13 PM
TPNORTH's Avatar
but also without the pill it does the same thing it throws the ecu out and puts the car in safe mode
Old Jul 31, 2009 | 04:29 PM
blacksti's Avatar
DudeMan
but it wont... the bigger the opening the farther away its going to be from targeted boost
a pill with a smaller opening will cause you to overboost... you have it backwards
2jz mustang build
Old Jul 31, 2009 | 04:49 PM
chome's Avatar
Gotchya.
Old Jul 31, 2009 | 05:17 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
Without the pill it hits ~7psi.
Trust me, I know from experience .
-Winston Churchill
Old Jul 31, 2009 | 08:34 PM
  #17 (permalink)
scoobywrx2's Avatar
listen to nick lol.. i had the same problem when tuning and nick solved my problem.. get the pill and get the right size.
Old Aug 1, 2009 | 05:28 AM
  #18 (permalink)
TPNORTH's Avatar
i did get the pill and all new lines but still no luck but a friend has a turboxs sitting in his engine bay and i bought it off him and now the car is running fine on that
Old Aug 1, 2009 | 09:31 AM
  #19 (permalink)
chome's Avatar
Can I have your old boost solenoid? I want to run 7 psi lol
