Subaru Tech All We'll Drive
Help on new setup
Old May 25, 2009 | 04:23 PM
I'm Slow's Avatar
I'm Slow
Don't worry about deleting the tgv's. Its not worth all the work involved to just delete the tgv's. If the manifold has to come off because you are doing a aps inlet or something then sure, while your there delete them but it's pointless to just do the tgv's it's more hassle then performance gain.
Old May 25, 2009 | 08:03 PM
randysti's Avatar
ok what do you think, the hta fp green, deatsch work 850cc injectors, and a walbro 255, is this a fair setup??? with the mods i have also how much power will this roughly make along with jeffs tuning
with that all said, i found at jscspeed.com the green was 1500, the injectors are about 550, pump has been bought, so are these good prices or can you guys find them
2008 Lexus ISF
2007 Aprilia RSV 1000R > Leo Vince full
Old May 25, 2009 | 08:31 PM
blacksti's Avatar
DudeMan
check nasioc for group buys i got my green over 100$ off and ported for free
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old May 25, 2009 | 08:52 PM
I'm Slow's Avatar
I'm Slow
Realistically the power you are going to make depends mainly on your car and your tune. The actual turbo and setup you have is good for about 400 whp depending on the dyno and how aggressive the tune is. Some people make 360~ whp some make 400~ few ever hit 450 ..... but a dyno # is just a number. IMO 400 on pump would be asking a lot from that turbo setup. Take ss advice to and get a fmic. You can get a ssac for $300 cheaper then any tmic and it's prove, I made over 500whp with it
My guess:
360 on pump
Old May 26, 2009 | 02:30 AM
ShockerGT's Avatar
Shake n bake
From his sig it appears he already has a TurboXS FMIC
Old May 26, 2009 | 02:19 PM
randysti's Avatar
^ yes i has for the car i juust need the turbo, injectors and the pump and tune i was just looking to see the responses for this certain setup
2008 Lexus ISF
Old May 27, 2009 | 06:44 AM
  #17 (permalink)
SnowMann's Avatar
TR Shop Mod
You have a Perrin EBCS right? If not, I suggest some sort of aftermarket BCS (GM, Prodrive, etc...)
SnowMan tuning
Old May 27, 2009 | 11:28 AM
  #18 (permalink)
randysti's Avatar
i just have a manual bc i have the txs hpbc is that bad or should i just go ahead and buy a ebc if so which is a good one but not too expensive, as i have a budget haha and the turbo pump and injectors are about the limit nany suggestions would be great also
2008 Lexus ISF
Old May 27, 2009 | 12:06 PM
  #19 (permalink)
albie1kanobi's Avatar
The one and only.
ask your tuner and see what he prefers.
and the hta turbo is 57lb/min turbo and the dom3 is 52lb/min
"Is it blaspheme to swap a 4G63 into a Subaru? "
Old May 27, 2009 | 12:18 PM
  #20 (permalink)
blacksti's Avatar
DudeMan
whoa i always thought it was a 52/min so the hta green sits between a 30r and a 35r... wish they had that when i bought mine
2jz mustang build
