Weird, an engine code
ok, moved the wire away from the head. reset the ecu, let the engine warm up. made sure the dynamic multiplyer deal was at 1.0.. drove it a few miles, no code so far. so i guess only time will tell.
Coyote
Coyote
^ why not? I hit the gas . I watch the wideband......I haven't done a pull or even hit wot or anything like that. I just stay out of boost completely for the most part......I have done a little quick 1/4 throttle punch just to hear the turbo lol
550/550
I should still get 300 to the tank. Gadiel makes the tune very economical while out of boost and cruising. Hopefully I will control my urge of going WOT every commute, lol. I better if I want the motor to last with a lot of power.
550/550
no thats street 300 miles 15.9gl tank=18.8 mpg which can easily be done but that wont happen if youre wot all the time obviously if you drive it normal you can get that
