Weird, an engine code
I bought one at Mastro right after i swapped in the bigger turbo and it was 150.
Good luck finding the issue
-Winston Churchill
-Winston Churchill
Well that was only the p0134 code. that code is not there anymore. its now only the p0030. and like i said, i was playing with wiring so that may be the issue. i kind of hope its just a new sensor, but it wont be fixed for awhile. why why why!
Coyote
Coyote
^hahaha nick, sorry man.... when I asked "does it sound like somebody slapping a screwdriver against the intake manifold" and you said "yes!" with some sound of hope in your voice... that was painful for me, lol
Matt, 2 things: have you reset the ECU? Also, moisture in the connection could be the culprit. Theoretically, unless you melted or cut the wires (or yanked on them REALLY hard), you shouldn't be able to disturb them like that. Check the blue-heatshield wire and the connector near your GM BCS. Take a can of compressed air, clean the plug and socket, reset the ECU and see if that helps.
Coyote
Coyote
hopefully its just getting too hot and doesn't need a new sensor... O2 sensors are pretty damn sensitive, I know someone who broke a brand new one by dropping it on the ground from only about 10" up
[/center]
[/center]
yep, im a zip-tier now. i thought the loom covering all of my wiring in that corner would look good, it just looks like a big mess of loom now lol. ill take pics later, you can tell me what you think.
Coyote
Coyote
