Subaru Tech All We'll Drive
The perfect street STi?
Old Mar 7, 2009 | 12:25 PM
racer_x's Avatar
vroom psshh.
Default The perfect street STi?
I'm thinking an 05 for body style (just preference), 04 gear shifter (lighter feel), 07 tranny / diffs (superior gears), VF-48 turbo (I think they fit?), stage 2, water meth, aggressive protune and a FMIC? Just until it blows up...
..and the real motor goes in
Old Mar 7, 2009 | 12:48 PM
ugmSTI433's Avatar
Classy STI Driver
Only thing I disagree with is the VF-48. They make more midrange torque than the 39/43 when at stage 2+, but have inferior top end. The 07 gears will only exaggerate this. Need proof? The 08-09 STI has a lower redline than the 04-07 STI. Just a thought.
Maybe just a ported/polished 43? If you want to have a stock turbo STI...
Andrew's 2007 UGM STi Limited #433
Defi Red Racer Boost + Oil Pressure | Innovate WB A/F | V1 radar | Cobb AP protune | Spearco TMIC | APS 3" catted TBE | APS CAI | APS turbo inlet | DeatschWerks 750cc injectors| Walbro FP | Beatrush forged pitching stopper | Kartboy hangers |Coolant bypass | Prodrive EBCS | Debadged trunk | Cobb heatshield |DRL delete | Autospeed dead pedal + black license plate trim | Primitive Armor |
284whp/307wtq
(mustang dyno)
Old Mar 7, 2009 | 01:04 PM
LDadrenaline's Avatar
yeah, I drive a miata
id say go with an EWG instead of spending money on meth. Like ugm said, get it ported/polished. Definitely helps. I also don't see why you need an "aggressive" protune. You will only be making like 5-10whp more than a safe tune and you will be running a much higher risk of blowing it up. Like in my car I had about 15whp on the table but snowman knew what I was using the car for and made sure that it ran 100% without blowing anything up. Car had 30k HARD DRIVEN miles on the engine and it never skipped a beat or burned a drop of oil.
....until the fire burned through the external oil cooler hose, then it burned a lot of oil
[/center]
Old Mar 7, 2009 | 01:50 PM
blacksti's Avatar
DudeMan
horrible.... why would you say vf series and perfect in the same sentence
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Mar 7, 2009 | 02:53 PM
ShockerGT's Avatar
Shake n bake
I dont know about a VF turbo, unless it were twin scroll. I'd rather run a 44lb/min turbo for an around the town monster.
Old Mar 7, 2009 | 04:16 PM
Sleeping_92_SI's Avatar
I kill 32-bit ECUs
This.....
I would go the meth route if your not afraid of the consequences. Spraying 100% meth would be almost like running c16 every time you got on it.
Can you say a lot of timing, and stupid boost. Trick is finding a tuner that's meth savvy and knows how to really manipulate the timing/fuel map accordingly.
(I've seen a lot of tunes with standard timing when meth is at full volume, and rich afrs as it were on pump)
Drunmann Tuning's Scoob: 2.55 liter-6spd swapped Bugeye, fully built w/280 cams and a rotated Precision-6266
DD: 2010 MazdaSpeed3: Fully bolted and tuned
Drift Missile: S13 DOHC swap, welded diff = slidetastic
Bicycle: Kawi 636R.
Old Mar 7, 2009 | 04:18 PM
blacksti's Avatar
DudeMan
its all about adding secondary injectors and spraying e100 when you get into boost
2jz mustang build
Old Mar 7, 2009 | 05:09 PM
racer_x's Avatar
vroom psshh.
the VF series has superior spool, Andrew I think you're right about the 48...
I will most definitely be going with a much larger turbo and setup for the built motor, but I kinda want to run a stock ej25/vf series until it explodes... I dunno, maybe I'll do a G series on that stock block
secondary injectors is an interesting idea for the real motor.........
Old Mar 7, 2009 | 05:19 PM
blacksti's Avatar
DudeMan
so youre actually gonna go waste money and throw an 07 tranny in an 05? for some reason im gonna call bs because thats just retarded for a few more mph on a few gears and if you have a good tune you can run a 35r on a stock block.... just be careful with picking that person... unlike what i did
2jz mustang build
Old Mar 7, 2009 | 05:21 PM
subiefan7162's Avatar
aggressive tune for the win because if your gonna build why not go full on and its not all about the extra 5 to 10 whp it also has to do with the better response, aggressiveness of the motor, better powerband, there are too many things to be gained with an aggressive tune over a conservative tune. and lol to blacksti on the vf comment lol so true though...
