Clutch recommendations.
I was going to have S & R do my work and hopefully buy through them too.....less headaches normally that way...
I have to get the ringlands redone so I am doing everythign at once to save a couple bucks....I may do cams porting and polishing who knows I am trying to get feedback on the legacygt.com site on suggestions for internal mods....
^ sounds good to me
I am under the addage "do it once and do it right" when it comes to clutches. One reccommendation is to look at what the EVO guys are doing and go a similar route, since changing one on an EVO is like a billion dollars in labor.
I strongly prefer the Exedys, as Exedy/Daikan make a huge number of OEM clutches and last for tens of thousands of miles without issues even from the most uncaring drivers.
If it were my own car, I'd probably opt for an Exedy Hyper Single. Yes, it's a lot of money, but it gives you the power holding capability and relatively easy engagement and is tough enough to handle just about anything you can through it from a durability standpoint.
If that's not within your budget and Exedy doesn't make a conventional disc, my second choice would probably be the ACT sprung 6-puck with HD pressure plate. If you go with a sprung center, the 6 puck drives very similar to a full face piece in terms of engagement.
BTTS, STFU&D
BTTS, STFU&D
thanks guys...if act is too much spec makes a nice alternative as well
you need to stay sprung for daily drivers...there are plenty of sprung options out there.
Rides-
2012 GTR
2011 WRX
2009 GTR
www.IMPORTIMAGERACING.COM
With over $10million sold, 30,000+ happy customers, over 100 brands to chose from, at the best pricing...best customer service...No wonder so many choose Import Image!
Rides-
2012 GTR
2011 WRX
2009 GTR
importimageracing.com ftw! josh always has the best prices and fastest shipping!
2011 Mustang GT 5.0
Sterling Grey Metallic
401a, comfort pkg, electronics pkg, security pkg, 3.73 gears
Orderd Sept. 29th, Built Nov. 8th, Delivered Nov 18th!!!
2011 Mustang GT 5.0
I know the information is out there and I have been searching for the past hour and cant seem to find what I need. Maybe someone can help that knows off the top of their head.
What is the weight of the stock 06 legacy gt clutch and flywheel? I would also like to find out the weight of the 06 wrx flywheel.
I am trying to find a stage two setup clutch but keep the factory weight, I want no vibration or clutch chatter then I would experience with an oem one.
I am not looking to save weight just looking to hold more power.
I am considering ACT, Spec, competition clutch, and exedy right now.
"Is it blaspheme to swap a 4G63 into a Subaru?
