Subaru Tech All We'll Drive
what would cause this?
Old Jan 23, 2009 | 01:34 PM
specVmatt's Avatar
400hp club, barely
Default what would cause this?
got on it somewhat in second gear, about 4k rpm.. i hit what seemed to be fuel cut. wtf? so i just cruised very nicely, and stopped at the next light. car idled perfectly fine, but my uego was reading 11.1-11.4 constant. so i pulled over and shut the car off. everything is back to normal. should i be concerned?
Coyote
Old Jan 23, 2009 | 01:40 PM
blacksti's Avatar
DudeMan
did you throw any codes? and check lines
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Jan 23, 2009 | 02:00 PM
specVmatt's Avatar
400hp club, barely
no codes, and the car runs perfectly fine now.
Coyote
Old Jan 23, 2009 | 02:11 PM
blacksti's Avatar
DudeMan
so what exactly happened? did it just like stop power instantly? if so check your crank case vent line on the heads because that happened to me once and one popped off
2jz mustang build
Old Jan 23, 2009 | 02:13 PM
specVmatt's Avatar
400hp club, barely
alright ill check thanks bro. but yeah, it just stoppped instantly. almost like i hit the revlimiter.. but at around 4k.
Coyote
Old Jan 23, 2009 | 02:14 PM
WTFchuck's Avatar
oh WTF
lemme guess... u were tuned in warmer weather then right now... u maybe hit boost cut due to the coldness
2011 Mustang GT 5.0
Sterling Grey Metallic
401a, comfort pkg, electronics pkg, security pkg, 3.73 gears
Orderd Sept. 29th, Built Nov. 8th, Delivered Nov 18th!!!
Old Jan 23, 2009 | 02:24 PM
specVmatt's Avatar
400hp club, barely
i was tuned at about 70 degrees. so yeah a bit warmer. but last night, i hit almost 24 psi. so that freaked me out. i dunno why i hit 23.5psi last night and no boost cut but at the awd cruise i hit 20.5(which is target boost) and i hit boost cut. i dont get it.
Coyote
Old Jan 23, 2009 | 02:43 PM
WTFchuck's Avatar
oh WTF
depends on load/engine rpm
2011 Mustang GT 5.0
Old Jan 24, 2009 | 02:30 AM
00lgt's Avatar
Boost cut should have a cel
jst4shw
Old Jan 24, 2009 | 06:22 AM
racer_x's Avatar
vroom psshh.
how much boost are you tuned for? My coils on my audi caused a similar problem a couple of times before they went out completely. You'll almost always throw a code with that, though.
