Subaru Tech All We'll Drive
Engine Trouble under boost
Old Jan 17, 2009 | 08:02 AM
M_Coupe's Avatar
The Antiriced
Default Engine Trouble under boost
Thursday night I was coming home from the gym & when the car gets under boost I lose a cylinder. I'm pretty sure it's the front right, because I did a spark plug swap & 3 out of 4 were the same, but the front right had deposits & seemed glazed. I was thinking the plug swap solved the problem, but it remains. Any suggestions?
Also I'm running a Hydra, so doing a code scan with the ODB2 isn't an option unless I swap the factory ecu back in.
I also have a Garret G35 turbo, Perrin Front mount, down pipe, intake & fuel rails, Apex cat back, PE 850cc injectors... blah blah blah... I can't think of any other info that would be useful.
Any help or ideas would be appreciated. I'm now thinking it could be a bad coil, but don't want to just keep doing the part swap thing due to costs.
Thanks
Dave
Drive it like you stole it!
Old Jan 17, 2009 | 09:15 AM
racer_x's Avatar
vroom psshh.
you need to find a local with a coil that you can borrow. Swap it, try it, see if that works. Post up your results...
Old Jan 17, 2009 | 09:29 AM
blacksti's Avatar
DudeMan
do a compression test also... well you can borrow one of my coils if you need to if your compression test comes back good
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Jan 17, 2009 | 09:35 AM
racer_x's Avatar
vroom psshh.
^I agree, but I'd do the coil swap first because of how quick it is
Old Jan 17, 2009 | 09:37 AM
blacksti's Avatar
DudeMan
well compression test involves just taking out the spark plug
2jz mustang build
Old Jan 17, 2009 | 09:41 AM
racer_x's Avatar
vroom psshh.
I know lol, and I guess it would be better to do the comp test first because if he's guessing wrong about the cyl that's missing, it's going to be more work.
Old Jan 17, 2009 | 07:56 PM
M_Coupe's Avatar
The Antiriced
I don't think I have a gauge to check compression. My dad may have one, but he's a Corvette guy & not the biggest fan of metric. I'm not thinking it's the rings or anything, because I'm not seeing any fluids passing through anywhere... I actually drained the oil after messing with the plugs to install a Fumoto valve & it seemed cool.
My old man messes with race motors, so I trust his judgement & he thinks the compression is fine. He mentioned it seems like an electrical problem because it's more difficult for the spark to handle the more dense fuel supply of the boosted cylinder. If it's not the coil, my next guess is an injector problem, but we'll see...
I'd appreciate being able to use your coil blacksti, but wouldn't want your car crippled in the process. I've got to do some family stuff tomorrow, when would work well for you?
Old Jan 17, 2009 | 08:03 PM
blacksti's Avatar
DudeMan
my cars being ripped apart and wont be running for around 6months i already have my coils out so just come by and we can see if thats your problem
2jz mustang build
Old Jan 18, 2009 | 07:54 AM
I'm Slow's Avatar
I'm Slow
Is the car idling rough? Pull out the coil pack in question and see if there is a difference in idle.
Old Jan 18, 2009 | 05:48 PM
M_Coupe's Avatar
The Antiriced
Low RPMs aren't bad, it's just high revs in boost condition. I've actually been driving it & just shifting around 4 grand. The car feels normal doing this. Plenty of power, no issues.
